Question about Roadstar LCD7310 7 in. Portable TV
Tunes in to channels but just craclkling sounds
  • 144 Answers
Make sure your sound setup is correct for your country does not auto change when you save the tuned channel
Posted on Oct 11, 2010
  • kinesin May 06, 2011
    How do you set up sound setting for a country? I don't have my manual anymore
I get sound on new channel but no picture with invalid format across the screen. Why ??? What does this mean
the format used when you tuned is incorrect
the correct way is to go to the onscreen menu and find the tune section and go auto tune
allow time for the auto tune to find all channels then exit
Mar 01, 2016 | Televison & Video
Help I have sound on the new 7fix channel but no picture all it says is invalid format. What does this mean.
go to the onscreen menu and allow the auto tune to do the job
there are also extra channel 9 channels and the one auto tune will bring all channels
On one channel...PBS we do not get any sound. Sound is ok on other channels and works on the other tv in the house
This television must have the ability to broadcast channels in SAP. Look for an SAP or MTS or AUDIO button on your Sylvania remote. The audio menu might be the place to find this setting as well. You want to remove the SAP and have the tv in either mono or stereo.
Sep 01, 2011 | Sylvania Televison & Video
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
Lg tv has no picture nor sound just the backlite, the remote control works, because when I press any key the power light flashes
The sound and video signal on LGs are driven directly from the mainboard which suggests a faulty mainboard..If the channels were tuned in previously to the fault then this solution is futher backed up. If the channels were not tuned in prior to the fault then you wont get any sound until the channels are tuned in, and it would not be possible to see the menu to do so. The prescence of REMCON pulses suggest the PSU is delivering power to the mainboard..Id go with a new mainboard but providing the channels are tuned in ok with no sound.
Oct 17, 2009 | LG Televison & Video
Any idea why on my new sharp 32" lcd tv, all cable channels except 57 & 58 (CNN) work fine, but on these channels the sound goes off and on, like there is a short in the sound. all other tvs and cable work...
If you do not have problems with picture and sound on all the other working channels, then the problem you are having with 57 & 58 cannot be a short. The problem you are having is that those channels will not tune in properly through your tuner and this is why you get intermittent sound when they are trying to tune in. The sound tunes in easier than the picture. You said that you have programmed the channels again and I am assuming you are talking about the autoprogramming mode. Try to program those channels individually by deleting them and then readding them. If you cannot do that then you need to take the tv back since it is new or have warranty service look at your tuner and setup your tuner by making adjustments to it directly. Good luck and God bless.
Jan 22, 2009 | Televison & Video
I have a poloriad flat lcd tv now channel 40 is the only channel where their is not sound all other channels have sound. We have cable and our other tv on channel 40 is ok but on the poloriad no sound on...
Could be the tuning of channel . Try doing an automatic channel search again and see if it will tune in more closely and get the full audio level.
Also, you might try a hard reset of the internal soft codes by unplugging it overnight to allow all the internal emproms to reset.
If the cable is passing through a vcr, could be the vcr at fault, too.
Jan 17, 2009 | Polaroid FLM-323B Television
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
No sound on 4 channels
i would say that it is the tuning try fine tuning it and see what that does
Apr 20, 2008 | Toshiba 20a43 20" TV
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Roadstar LCD7310 7 in. Portable TV Logo
107 people viewed this question
Top Roadstar Televison & Video Experts
Electro Med Services...
Are you a Roadstar Televison and Video Expert? Answer questions, earn points and help others
