Question about Maytag Neptune MDE5500AY Electric Dryer
My kenmore dryer isn't getting hot. What is the problem?
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 11, 2010
The dryer isn't getting hot
Here's a good troubleshooting article on them:
http://www.ehow.com/way_5389575_troubleshooting-kenmore-series-dryer.html
Keep in mind, it is an older dryer, but that series is known for being really good. If the article doesn't check out, I would suggest calling in a technician as it's possible something got damaged in the move/
Dec 31, 2012 | Kenmore Dryers
My kenmore oasis dryer comes on but doesn't run
The tumbler is belt-driven so it could be a broken or slipped belt. It isn't hard to replace the belt itself but sometimes getting to it can be a real pain. Search online for service manual or diagrams if you want to attempt it yourself.
Oct 05, 2012 | Kenmore Elite Oasis ST 6806 Electric Dryer
My dryer is turning but it isn't getting hot? What
dryer element not getting hot .possibly only 110 volts instead of the needed 220volts ...maybe a bad breaker in fuse box
Nov 29, 2011 | Kenmore Dryers
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer will get hot but will not dry clothes
If the dryer gets hot, but not drying the clothes my first question would be if the drum is turning or not. If not then I would check the belt and make sure it isn't busted. Then I would check to make sure that your exhause hose is not clogged up. If so clean out.
But if that isn't the problem then I would check the blower assembly.
Aug 07, 2011 | Dryers
The heating is not working properly, not hot enough. I tried 3 hours, but the clothes still not dry. It is a 120V Kenmore dryer.
IF THIS IS AN ELECTRIC DRYER 110 VOLTS ISN;T RIGHT 208 VOLTS SHOULD BE MORE LIKE THE ANSWER. IT TAKES 208 VOLTS TO RUN THE HEATING ELEMENT AND 120 VOLTS FOR THE MOTOR
SOMETHING DOSN'T SOUND RIGHT THERE
Feb 06, 2011 | Kenmore Dryers
My dryer isn`t get hot. What should i do? kenmore-400. I live in Pembroke Pines. Florida
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Dec 18, 2010 | Kenmore 400 6943 Dryer
Dryer shuts off when it gets hot but restarts
1.Remove your exhaust duck on the back of the dryer and clean it.
2.Make sure your exhaust going to the outside vent isn,t clog.
3.Check thermostat.
Mar 07, 2010 | Dryers
Kenmore Elite Oasis dryer 110.6708 that gets too hot
did u clean machine filters? in the back of your machine there is a big silver pipe itmay need to be clean too
Jan 21, 2010 | Kenmore 67082 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
61 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
