Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
I'm hooking up a new thermostat, Honeywell RTH2310. When I disconnected my old thermostat, I had a T, R, C, X, W, G, Y wires hooked up with the W wire also hooked into the X spot. On the instructions for the new thermostat, it said to only hook up the R, G, W, Y wires and tape everything else off and stuff back in the wall. I did that. So now I have Y, G, W, R wires hooked up (R wire is in the Rc postion and a jumper going from Rc to Rh). But when I went to turn on the A/C, all I get is heat. And if I turn on the heat, I still get heat. So I tried taking out the jumper between Rc and Rh, That didn't work. I tried moving the R wire to the Rh spot and put the jumper back in, That didnt work either. Am I doing something wrong here? Did that W wire hooked into the X position on my old thermostat have anything to do with this?? Any help is appreciated. Thanks
  • 59 Answers
Make sure the stat you have is for a heat pump
Posted on Oct 12, 2010
  • cdmaas Oct 26, 2010
    I have the same problem with both a gas heater downstairs and a heat pump upstairs. I can get the heat pump to give me cold air when I turn the thermostat to "heat". Obviously there is a mix up, but I have not seen anyone come up with a clear solution. bummer.
4 Suggested Answers
  • 1015 Answers
SOURCE: Honeywell RTH 221 Programmable Thermostat. Jumper missing
The proper way to do it would be to use a small piece of wire stripped at the ends. Then use a small amount fo solder on each end to connect RC to RH. Or use a small piece of solid(stiff) wire and strip the ends. The wrap the ends around the connector and crimp them to make contact. I would not use a paper clip. A paper clip is not designed to carry 24volt current and could melt.
Posted on Nov 02, 2009
heatman101
  • 43501 Answers
SOURCE: Wiring problem?
Yes to everything!!
You have it figured out!!
Just make SURE that the blue unused wire cannot touch any of the other wires, it will wreck your transformer in a split second.!
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Nov 25, 2009
  • 111 Answers
SOURCE: I just purchased a Honeywell RTH2310 and cant get
red is 24volt power, white is load,I.E. relay,touch the red and wht wires together, the furnace should start, if it don't the problem is the heater, Rheat-Rcool you have a heat/ac thermostat, no ac forget Rc,try turning thermostat all the way up, dig up a multi-meter or powered light tester, touch Rh with one wire of tester,touch the other wire to different terminals until it lights,hook up your wires, you should have heat
Posted on Jan 31, 2010
Bought new thermostat model ct87k but old Honeywell model I have was hook up by black and white wire not red and white , so how do I hook up.
The two wire Honeywell T87 and CT87 is nothing but a switch in a control circuit. Wire color is not important at all. What is important is the TERMINAL DESIGNATION those wires are hooked to. Soooo....take the wire off of the sub base of the old stat terminal marked 'R' and attach it to the new sub base terminal marked 'R' and so on. Wire COLOR means nothing at all in your case.
Oct 04, 2014 | Honeywell CT87K1004 Round Heat Only...
Wiring with new Honeywell thermostat
You need to put battery in the new thermostat if you gonna leave the C terminal disconnected
Jun 21, 2017 | Heating & Cooling
Only have two wires on old thermostat,where do i hook them up on a rth2310 thermostat
More information would help but I believe that you are trying to hook up a programmable thermostat to your old heating system which is what? Oil forced air, heat pump, gas? Give me more info and I think that I can help you.
hardrocko
Feb 07, 2010 | Honeywell Electronic Programmable...
I bought a Honeywell programmable thermostat RTH2310 to replace my 10 year old Honeywell thermostat. My old thermostat is a 4 wire system but also has a jumper from Y to 1. New system does not tell me what...
It depends on the type of thermostat you have.
Do you have a 4 wire or 5 wire T'stat?
The red jumper wire was for a 5 wire t'stat with 1 transformer, the red jumper actually should have been from R to 1.
So you need to trace the wires back to the furnace and make sure they go to the locations identified below.
if you have a 4 wire t'stat then you don't need that jumper, if you have a 5 wire t'stat then you do need that jumper but it should go from Rh to Rc.
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
t'stat?
Nov 14, 2009 | Honeywell Programmable Thermostat Heater
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
New rth2310 themostat does not blow cool air
I don't believe you're going to get the new one to work -- sounds like it doesn't have enough control wires to operate your HVAC system. If it is designed to operate a 7-wire system, the documentation should show how to hook the 4-wire tstat so it will work.
Apr 21, 2009 | Honeywell Focus 6300B 5-2 Days...
Hooking up wires. where?
Connect one wire to R or Rh.
Connect the other wire to W.
This should allow you to use the thermostat with battery power.
Nov 14, 2008 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
471 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
