Question about Samsung CXJ1352 13 in. TV/VCR Combo
Samsung tv - switch to play a dvd player
I have an older samsung tv with a built-in vcr player. I hooked it up to a dvd player, but can not figure out how to get it to play. Help!
    Problem Solver:
  • 14 Answers
All you should have to do is hit the TV/Video button on your remote. It also could be named AUX, or or INPUT. What this does is tells the tv to switch to the input you have the DVD player hooked up to. Otherwise it will keep drafting a signal off of your cable line.
Posted on May 31, 2008
I am trying to record cartoons for my 4 month old onto dvd from cable... I cant quite figure out how to hook it up.
The device unit?U must have DVD/VCR recorder player to record things out of cable tv or other tv signals.Not just a DVD/VCR player.Read ur manual for instruction,u hook up a VCR before right,the same principle.
Dec 07, 2010 | Samsung DVD-VR357
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Dec 04, 2010 | Samsung DVD-V9800 DVD Player/VCR
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
I have separate dvd player and vcr, how do I hook coverter box up
It took some time, but I finally have this figured it out so everything works.
I have the same setup, but I had one additional piece to the puzzle that I had to figure out. I have an older TV and use and antenna, but had to buy an Audio/Video RF Modulator a couple of years ago to use my VCR & DVD player with the old setup.
Get yourself an Audio/Vido RF Modulator (you can pick one up for about $20-30).
Connect the TV to the RF Modulator.
You should have 2 connectors for your antenna. Connect one to the converter "To Ant" and the other to the RF Modulator.
Connect the convertor A/V cable to "IN" on your VCR.
Connect the cable from converter "To TV (RF)" to "UHF/VHF from Ant" on VCR.
Connect the VCR "OUT" cable to the RF Modulator.
Connect DVD A/V cables to A/V input on VCR.
Your TV should be set to Channel 3 (or 4, depending on your setup) and depending on your "input" connections, you should be able to view vidoes from VCR like this and DVD by changing the input (the button should be on your VCR or other remote). For ex. my input changes on my VCR from channels, to L1 & L2. My converter & VCR play on L1 and DVD's play when I change it to L2.
Now, I just have to figure out how to add the converter box to my universal remote. :)
Feb 14, 2009 | Insignia Digital-to-Analog Converter for...
Vcr/dvd won't play
You may have to buy an RF modulator ($20.00 at any radio shack or wall-mart) this will allow the hook up to work! ( has a channel 3 or 4 selector switch!)
I hope this is of big help!
Please rate answer
Thank You!
Jan 16, 2009 | Samsung DVD-V4600 DVD Player/VCR
Switching my tv from tv setting to video setting to play vcr
Should be a button on the TV or remote that says Video or Mode. Make sure player is on before hitting the button and wait a few seconds.
Mar 21, 2008 | Televison & Video
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
My DVD player is, quite literally, on the blink...
Hi Your problem is Copy protection on your DVD's! Without going into techno-bable, your DVD player detects that you are connected to a VCR, (You have no choice in your case as it is built-in), there are methods such as "Copyguard" and "Macrovision" that try to stop you from copying your favorite DVD onto VHS. The audio is left alone, but the video will go bright and dim, and the colors will be messed up, making the result un-watchable. You will find that the cheap DVD's you get for a couple of bucks at the discount store will play fine, as it would be too expensive to protect them. There are "little black boxes" available as "video stabilizers" that will cure this problem, (but you didn't hear that from me!),otherwise you must connect into a t.v. without a built-in VCR. P.S. Make sure the t.v. you switch to has RCA type A/V inputs on it, as you will have to purchase a separate RF modulator otherwise. Good Luck!
Aug 15, 2006 | Emerson EWD7003 DVD Player
Samsung CXJ1352 13 in. TV/VCR Combo Logo
167 people viewed this question
Henry  Thomas
Henry Thomas
