SOURCE: Printing everything double sided
go in youre ip address, log in as admin, chooce print tab and there is a print tab, there is a default options, and choose double printing off
SOURCE: There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
SOURCE: i have a problem with a bizhub c451
sometimes especially when printing a pdf there is a box on the first print screen that pos up that says print actual size deselect that and then it will default and print on the paper that is available
SOURCE: my printer keeps printing double sided when I need
You will need to change the printer settings in your computer. The duplexing / double sided printing is obviously turned on.
SOURCE: hi can a Matching paper size is not available
If your copier is connected to your network and you get this error, the answer is no. If you are getting the miss match error then the print job could be stuck in the que. This would cause it not to print. If you dont know how to clear the print job, restart your computer and try to print again using the correct paper size.
