Question about Whirlpool LER5636P Electric Dryer
My dryer stopped heating but still goes through the cycles.
  • 755 Answers
Probably a damaged/broken heating coil.
You can unplug the dryer. Lift the upper cover up and swing it back to expose the heating coils. You can then look at them with a flashlight and see if you can visually id a bad coil section.
Replacement is pretty simple. Unplug the two spade connectors *(be sure the dryer is unplugged!) and lift the coil out of its heat shielded housing. Take to appliance parts store and swap for a new one and reinstall. It's practically like changing a light bulb!
Now if your dryers heating elements arent viewable from above then you need to pull out the dryer and work from the back. This element assembly differs only in the fact that the unit has one of the heating safety switches attached to the side of it. So you would need to remove this switch and put it on the new heating coil before putting the new coil back in.
Here is a nice picture of the various types of heating elements.
I priced the first two out at 20-26 dollars each.
Good luck and be careful.
Posted on Oct 11, 2010
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Why does dryer heat alittle while and goes off
the heat normally cycles on and off as needed. However, if your unit stops heating altogether and you see the igniter cycling on and off, the failure is with-in the gas valve solenoids. Replace the set. It's a 15 minute repair. A video to view is available at repair clinic .com as are the parts.
Jun 06, 2014 | Maytag Atlantis MDG8400AW Gas Dryer
Whirlpool dryer shuts off at the end of cycle, but timer continues to tick. It ticks through the next cycle and stops ticking at that cycles off?
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it.
Oct 01, 2013 | Whirlpool Dryers
My dryer heats up,, glow works, igniter works,, then cycles approx 3-4 times then stops cycling
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Oct 18, 2010 | Whirlpool LGV4634JQ Gas Dryer
The dryer stopped heating, The fluff air cycle still works but the heating cycles have stopped working. Is there an easy fix, or do I send it to the scrap metal yard?
heatman101
Oct 10, 2010 | Whirlpool LER4634J Electric Dryer
Stops heating untill totaly cools down runs 1 cycle then stops
heatman101
Sep 20, 2010 | Whirlpool LGQ9858P Gas Dryer
Dryer is not heating. the dryer timer goes all
HI, The timer control module is the culprit. This device controls the heating functions of your unit. You have indicated that the timer will not stop the unit, and it continues to run after the cycles intended stopping point. This will confirm that the timer is damaged, and it should be replaced asap, if possible.
NOTE:-( Just to be safe, check the thermal fuse as well. This is a emergency cut-off fuse that will blow if the element overheats your unit. it is located on the blower housing, or vent duct inside the unit. Test the fuse for continuity. If it is ok, replace the timer).
Oct 16, 2009 | Dryers
There is no heat generating out of my dryer
If you reset your breaker and it does not solve your problem. Your thermal fuse and cycling thermostat both are bad. When your cycling thermostat goes out the dryer cycles on the thermal fuse until it goes out. At that time it stops heating. Replace both. They are located on your element shoot.
Please rate solution
Sep 06, 2009 | Kenmore Dryers
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Whirlpool LER5636P Electric Dryer Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
