Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Gas to oil mixture for a RY 26540 - Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
    Scholar:
  • 150 Answers
50:1 don't use outboard motor mix
Posted on Oct 11, 2010
Fuel mixture ratio for Ryobi SS300 weed eater
Are you sure about the model number? I see several 30CC engine string trimmers by Ryobi. Two are the Ryobi RY30040B (SS30) and a RY30544 (SS30).
For both of these models, mix a high quality 2-cycle engine oil at 2.6 oz. per gallon of gasoline to pour into the gas tank. This ratio is used in several other Ryobi string trimmer models. Many Ryobi product manuals are available here: https://www.ryobitools.com/power-tools/support/manuals . Most Ryobi gas powered and 40V battery-powered tools will have a model number that starts with RY. The 18 V battery powered models often start with a P.
I hope this helps. If you add a comment with the actual model number, I may be able to provide more information.
May 20, 2016 | Ryobi Garden
I added 0.4 oz of oil to 1/2 gallon of gas too much to mixture. How can I dilute the mixture without starting over?
??? Take a gallon gas can, pour the I/2 gallon oil/gas mixture into it and then add the correct amount of undiluted gasoline to the correct mixture. For instance, if you need a .2 oz/I/2 gal ratio then add 1/2 gal gas to what you already have. Remember, it is always better to have a little too much oil than gas.
Jul 30, 2014 | Husqvarna Weed Eater 26 In Deck 190 CC...
Need gas and oil mixture ratio
The gas oil ratio on all Poulan models is 40:1.
First, I recommend a synthetic oil mix if you can find it and also recommend running a 93 octane gasoline.
Second, I would mix no more than 1 gallon at a time, unless you are doing a lot of cutting.
Gas/Oil mixtures do not last that long. I don't give them more than a month, and generally try to run any mixture within 2 weeks.
Think about it, gas cam gum up on it's own when let sitting for too long. Imagine what it can do with oil mixed in it.
Good luck with your saw, and be careful when cutting.
Jul 07, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
My ryobi grass trimmer will only run on 1/2 choke model RY 30524
Check for fuel supply problems (clogged cap vent, dirty tank fuel filter, clogged or faulty fuel intake lines, leaky or cracked primer bulb, air leak in rear crankcase cover...check 4 screws above gas tank, air leak in carb gasket...check carb nuts, trashed up carburetor...needs cleaning or rebuild, mixture screws need adjusting)....a myriad of possibilities here but I would guess it's a dirty carb....hope it helps
Jun 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas to oil mixture for Model # RY 28020
Use 2-Cycle Oil For Mixture of 50:1. They come in 2.6 oz bottles and larger. Use 2.6oz (one small bottle) per 1 gallon of 89 unleaded gasoline. I use and this and it runs like a charm. You can get from HomeDepot or other hardware stores.
Jun 18, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Oil and gas mixture
Mixture is typically 40 or 50 to 1, gas to oil. The exact mix should be stamped on the gas cap.
Apr 10, 2010 | Ryobi 15" Electric Factory Reconditioned...
Gas/ oil mixture
If it is a riding lawn mower it is probably not a two cycle engine so there would not be a gas oil mixture. It must be a 5 horse power or higher so it would use straight gas. I hope this will help you. donnyb60
Mar 20, 2009 | Poulan Garden
Fuel/oil mixture
3.2 oz oil in one US gallon yields 40:1 mixture.
2.6 oz oil in one US gallon yields 50:1 mixture.
Jan 15, 2009 | Humminbird 140c Fishin' Buddy
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
139 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
