Question about Cuisinart Kitchen Appliances - Others
I pressed the start button, not having set the proper setting on the menu! Now, i don't know how to change the setting!
    Champion:
  • 248 Answers
Try unplugging for at least 30 seconds and then trying to reset on menu
Posted on Oct 12, 2010
How do you shut off the annoying Bosch Nexxt 500 Dryer wrinkle guard?
Click HERE to get the Users Manual for your machine, from what I can see, it's in the selection option of the machine.
From the manual:
Select the option to be changed with the "Menu" button. Press the button to move to the next option on the display. The active symbol starts flashing.
The current active option setting is displayed on the right. These settings can now be changed with the "Select" button. Press the button to jump to the next possible setting. Pressing the "Menu" button again saves the setting. If you don't press any buttons for 10 seconds the settings are saved automatically.
Hope this answers your question. Please rate and comment. Thank You
Joe
Sep 01, 2011 | Bosch Nexxt 500 Plus Dryer
Cannot change the language to english it is currently japanise
looks like you have to reset it
to do that slide the hold button to hold and then back
then press and hold the menu and the center buttons at the same time for about 7-8 seconds until the apple logo shows on screen
if after resetting, the language is still Japaneses, then do this
Scroll down to the last menu option but don't select it.
Scroll up one menu item. This should be Settings.
Press the Center (Select) button. This takes you to the Settings menu.
Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
Scroll up to the third menu item from the bottom one. This should be Language.
Press the Center button to select Language.
Select your preferred language from the list.
Jul 18, 2011 | Audio Players & Recorders
I don't know how to change the time and date
  1. Press the CONFIG button.
  2. Select Time and Date Settings.
  3. Select Set Time or Set Date.
  4. Turn the MENU/SELECT knob to adjust the highlighted value.
  5. Press the MENU/SELECT button to select the next value.
  6. To save the time or date and return to the Time and Date Settings menu, press the BACK button at any time or press the MENU/SELECT button after adjusting the minutes or year.
Jul 01, 2011 | 2010 Chevrolet Camaro
Hi i need to set gprs setting manually on my mileston xt720 i check the phone but don't know how to change it .please help
Firstly, bear in mind your carrier's APN settings. Contact they, in case you don't know such data for sure.
Then, go to 'Menu > Settings > Wireless & networks > Mobile networks > Access Point names'. Once there, press 'Menu > New APN', and fill in a 'Name' for it, and, at least, your carrier's data under 'APN', 'Username' and 'Password'. Then, press 'Menu > Save'. Press the back button as many times as required for you to reach the home screen you were in, prior you've started making these changes.
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Regards,
Carlos
May 07, 2011 | Motorola Mobility MILESTONE XT720 Cell...
How to get internet setting about connect
f you mean you want to access the internet through your network carrier's data plan, bear in mind their APN settings. Contact they, in case you don't know such data.
Then, go to 'Menu > Settings > Wireless & networks > Mobile networks > Access Point names'. Once there, press 'Menu > New APN', and fill in a 'Name' for it, and, at least, your carrier's data under 'APN', 'Username' and 'Password'. Then, press 'Menu > Save'. Press the back button as many times as required for you to reach the home screen you were in, prior you started making these changes.
Regards, Carlos
Apr 15, 2011 | Motorola Mobility Defy Cell Phone
Asko Dryer t760 program menu won't change or is frozen The program menu is stuck on one setting, and the P1, P2, P3, P4 buttons don't change the program. When I try to reset the program (by pressing...
Welcome to FixYa.
By stating "the dryer does work" indicates it is likely an issue with programming.
What are the chances you have the menu lock-out option turned "on"...also referred to as "child lock".
You may quickly rule this out or confirm it is the problem indeed, by trying this.
CHILD-SAFE START
1. Turn the machine off then on.
2. Press ENTER five times, then press P3 five
times. (This must be done within 15 seconds.)
3. “Delayed start” displays with “0” flashing in the
lower right corner. Press the Right Arrow button
to toggle the display to “3.”
**NOTE: Child-Safe Menu Button**
Please note that when you set the child-safe Start
button, the Menu button is automatically
programmed to delay for three seconds before it
becomes active. This prevents a child from
accidentally changing the program settings.
When you want to change a program, press the Menu
button for three seconds to activate the menus. The
Menu button will work normally (without the
three-second delay) until you have completed your
changes. If it is not pressed for two minutes, it will
automatically revert back to the child-safe mode.
Let me know if this indeed solves the problem but either way please keep me posted.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Sep 18, 2010 | Asko T761 Electric Dryer
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
Cd/dvd player is not working
Hello, Follow the instruction:
Press power button and enter BIOS menu. (Bios menu: while PC make sound beep press button "delete")
You can see there BIOS menu. (Be carefully, don`t change anything if you can`t understand something) You have to find there general settings and in general settings you will see boot button.
There will be many boot buttons, but your settings must be that:
First boot: FDD (do not change it)
Second boot: HDD (do not change it)
Third boot: CDROM (if it is not, change it to CDROM or DVD/CDROM)
Sep 05, 2008 | Microsoft Windows XP Professional With...
Putting right the ip address ?
Before you proceed you need to know the static IP, Subnet Mask and Gateway address for this printer. Once you have them: -Enter the menu mode by pressing the + button -Press the + button till you come to the Network Menu. -Press the Enter button. You should now see TCP/IP. Make sure it says Enabled which is the default setting. -Press the + button till you come to IP address then press the Enter button. - IP addresses (for now) consist of four octets or four groupings of three numbers such as in this example *192.168.001.123*. Using the + or - buttons (+ counts up 0,1,2,3?.; - counts down 255,254,253?..) you are going to set the number of the first octet or in the case of the example *192*. Once you?ve set it correctly hit the Enter button. -Do the same for the other three octets. Hitting the Enter button after setting the fourth octet will set the new IP and take you back to the TCP/IP menu. - Press the + button till you see Subnet Mask and press the enter button. - Just like the IP address the Subnet Mast consists of four octets. Set the value to you needs just as you did with the IP address. Again when you hit the enter button after setting the fourth octet you will be taken back to the TCP/IP menu. - Again press the + button till you come to Gateway Address and hit enter. Enter the Gateway IP address exactly like you did when setting the IP address. Don?t forget to hit the enter button to set the address. You should now be at the TCP/IP menu again. -To exit the menu press the On-line button on the printer. Your printer should now be configured with you IP address, subnet mask and gateway address. As an added check I would go back into the menu by pressing the + button, going into the Information Menu and printing selecting the Print Menu Map option. Verify the setting we just made with what is printed out at the top of the page. If everything matches you?re ready to go! Let us know how it goes and please don?t forget to rate this posting.
Jan 22, 2007 | OKI C5100n Laser Printer
Loss of ethernet card after reset
u need to put the right IP again, do u know how to do it??? if don´t ask again.
Jan 13, 2007 | OKI C5100n Laser Printer
Kitchen Appliances - Others Logo
113 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
