Question about Acer X193W LCD Monitor
Desktop is dispalyed horizontal on monitor
Can u please tell me how to change the display from horizontal back to vertical
cheers
christine
  • Acer Master
  • 19,396 Answers
The Ctrl-alt direction key sequence is supposed to be used for changing your workspace. On my computer at work it changes the screen orientation Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
(If that doesn’t work, try Ctrl-Shift-R)
Posted on May 31, 2008
How do i change the screen from vertical display to horizontal
The IBM ThinkPad Z61t computer runs the Windows operating system. Normally, Windows is displayed on a monitor in a manner that makes it easy to read. If you want to change the screen display configuration (from vertical to horizontal), modify the screen display properties in Windows itself. This process causes the computer to rotate the image displayed on the screen by 90, 180 or 270 degrees, depending on the setting you choose.
1.Right-click on an empty portion of the Windows desktop on the Z61t.
2.Click "Properties."
3.Click "Display."
4.Click "Change display settings."
5.Click the "Orientation" drop-down window. Select the "Landscape" option to make the screen display items in a horizontal manner.
Sep 19, 2011 | Lenovo ThinkPad Z61t Notebook
LG 700B SHAPE SIZE AND POSITION UPSET PLEASE HELP TO RESTORE
Push the button on the Monitor to activate the OSD (On Screen Display). With the OSD, one can "stretch" the picture (horizontally/vertically) and "move" the picture (horizontally/vertically) in order to "fill" the viewable area with your compueter's output.
May 09, 2010 | LG Flatron F700B 17" CRT Monitor
Monitor screen is showing sideways....in other words, the vertical is horizontal and vice versa. How do I make it go back?
If your video card has installed software go into the application and find the display property you should be able to change it through there. If not find the display button on your monitor and try that feature.
Dec 29, 2009 | Acer AL2216WBD LCD Monitor
Gateway LP2417 monitor won't work horizontally
I had the same problem on both of my LP2417 monitors. It turned out that there was a swivel software installed that was causing the problem. I found it in my taskbar and it didn't work when trying to swivel the monitor so I went into my control panel, add/remove programs, found the offending software and uninstalled it. After a reboot I was able to control my monitor swivel with my built-in Windows desktop preferences.
I'm sorry I don't recall the exact software name (its been a few months) but it shouldn't be too hard to find.
Apr 05, 2009 | Gateway 24" Widescreen Flat Panel TFT LCD...
Monitor is vertical display instead of horizontal display
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Oct 10, 2008 | ViewSonic VA902 19" LCD Monitor
Monitor display is vertical instead of horizontal
What Video card are you using?
WIN XP
Right click Desktop>>>Graphics Options or
Right Click Desktop>>>Properties>>Settings>>>Advance
and change the rotation to NORMAL
For Intel Video card go to GRAPHICS Properties
For ATI Video card go to CATALYST
For NVIDIA Video card go to PHYSx
Oct 09, 2008 | Dell Computers & Internet
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Horizontal display
Check with the manufacturer information that you have the refresh rates and maximum resolution set correctly. If in doubt, go to your display properties and try something basic to test if this is the problem. A basic setting may be as low as 1024x768 at 60 Hz.
(You can access your display settings by right-click the desktop anywhere and choose properties, then settings).
Leave the monitor at that setting for a while to see if the monitor changes the picture.
If the picture changes, it may be component failure in the monitor. If not, the problem is then related to the settings from your VGA card are too high or dense causing the monitor to fail after a time. Try something higher like 1280x1024 @ 60Hz and keep going till the picture fails. Compare the best functioning resolution with the manufacturer claims about the product in the product documentation.
Be sure there are no cable bunches and the power cables are not wrapped up with the VGA cable under the desk or there are not too many cables lying about, although unlikely, this has been known to distort the picture.
Let us know if this helps.
Cheers
Gund
Mar 30, 2008 | LG Studioworks 775N 17" CRT Monitor
Display on monitor has swapped from vertical to horizontal
Type ctrl-alt then use the up, down, left, and right arrow keys until it's where it's supposed to be. If that doesn't work, right click on the desktop, select graphics properties. Then there should be a display settings, there you'll see where you can change the rotation of the display.
Aug 08, 2007 | Hyundai ImageQuest ImageQuest Q15S...
Acer X193W LCD Monitor Logo
188 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
