HP Compaq Presario V2000 Notebook Logo
Posted on May 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Screen is dark
When I boot up my computer, everything seems to load just fine but I can't see the screen. If I tilt it up to the light I can see a little of it. Is this a common problem? Please tell me there is an easy fix. I think it's three years old.
Anonymous
Level 2:
Scholar:
  • Expert 125 Answers
  • Posted on Jun 01, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
125
Questions
0
Helped
62308
Points
362
It would seem that your backlight is not turning on.
First check to see if the switch that detects that the lid closed is working. I am not sure where it is on this model, but all notebooks have one. If it gets stuck, the backlight stays off.
If it is not the switch, it may be the flourescent backlight
tubes or the inverter, It's not an easy fix, but you can check back here.
  • Principal Trustee
    Principal Trustee Oct 10, 2015
    I have the same problem - can see the open desktop when I hold a lamp up to the screen. Also when I flick the lid-switch the screen flashes with light on about 1/2 of the screen, but dimly, then goes dark again. How can I determine if it's the inverter or the fluo..backlight?
    [email protected]
1helpful
Samsung LN37B530 37" LCD TV
Sounds like your Tcon board is giving issues.
1helpful
Emachines T6524 won't reboot after automatic update. I get the windows screen when I turn it on, and everything seems fine, then the screen goes black and I get the no signal message.
You should try to boot in safe mode without the card removed..If this got on after an update it is possible (almost sure) it messed up with your graphic card driver and now it needs to be reinstalled > To do so ..try to boot in safe mode...To do that press the key indicated on screen for boot menu and choose safe mode ...usually it is f8 key or f12 ..depend on the model .If it seams not to be able to find the safe mode boot ..try to stop the computer by unplugging it ..This will force it to stop improper way ..and will show the screen for safe mode and other ways to boot-up .select the first safe mode ..and let it start ..This mode will not load any drivers and work just with the minimum needed for to start .Go to control panel ...remove programs ..and remove the graphic card driver from the list ..after that if you have the disk insert it and run the driver again in original ..If you do not have it look for it on the manufacturer's site ..and download it ..
If you need help with the driver ..let me know exact model of the computer ..and if it is not an on board card I need to know the exact model of the video card ..
Dark screen,but can see display if tilted,boots up fine
can be the brightness setting of the laptop's screen..have it change to the appropriate brightness setting then you're all set :)
I have an IBM T41 type 2378 Windows XP Professional. I have been using and external monitor as the screen does not work. A while back I wanted to reformat my C drive and installed a windows XP disk I...
I would try to start it up in safe mode. This can tell you whether it's a display (physical) issue, or a driver (software) issue. You can do this by hitting the F8 button as soon as you start the computer and it brings up a prompt. At the Advanced system prompt, choose "Safe Mode with Networking" and see if it works then. If it does, I would suggest you undo an changes in the drivers that you made before.
My dell inspirion 6000 laptop screen goes black but sometimes I can see the windows screen but it's very dark. When I attach it to a desktop monitor it works fine but the laptop is still dark. Sometime the...
The back light is the whole of the screen, the screen is illuminated by a CCFL lamp (fluro tube) on the bottom of the screen. A inverter supplies high voltage to this CCFL lamp.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
I have a tecra m2-s730 that displays the boot screen then back light goes out but you can still see image..what could be problem
1) test it to an external source like a tv, or external monitor through the vga ports, svideo ports. If promblem is solved, and everything seems to be going normal, then your screen is history, bad backlighting and needs screen replacement. 2) Bootup screens seems to work fine, ( like it has backlighting and light all work fine and normal) but when it turns over to loading your o/s and it get dark even with a external monitor, then it's a driver issue or your vga chipset is bad and you will need to replace your motherboard, ( in this case it is best to buy a new laptop). 3) Bios error issue, bios has become currupt somehow, you can try loading default value given in the exit tab in your bios menu. Load and save and exit. See if it works, if not your VGA chipset is screw, and motherboard will need to be replaced to fix this issue.
1helpful
Computer turns on and boots up , however, the
No the screen is fine the back light is not working you have replace the back light of the screen to resolve the issue.But before that please try the FN+F6 or F7 keys to control the brightness.
I have a Acer Ferrari 4006wlmi it boots and
Hi...
You need to reinstall the OS.
Let me know
Thanks
Smith
1helpful
Laptop screen goes dark while loadin windows
If you can see everything when you shine a light on it, it's most likely a 'backlight' going bad. These are somewhat easily repaired, but can be expensive. Good luck!
2answers
Screen won't turn on
when the computer boots does the screen light up? if it does the first thing you need to try is when you turn the computer on is to option boot. That is done by holding the option key while turning the computer on. after it boots you will see the the hard drive listed on the screen it will be a icon, if there you should be able to boot up. If the computer does not boot and your hard drive is still listed you most likely have a logic board aka mother board issue.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
