Drc282 program codes for remote setup dvd is drc282 remote is 1056b01 what is the 4 number codes
  • KnightEagle Jun 01, 2008
    have tryed every code that came in the book for a rca DRC282 DVD Player with HDMI 1080p from timewarner they are alot of help yea right.
How to remove the Zoom menu from the screen while zooming?
Posted on Jul 17, 2008
SINOTEC DVD - 8161 does not work with One for All remote. Need correct code to program please!
0381,0389,0384,0388. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 15, 2013 | One For All URC-5705 Remote Control
I need a remote for my RCA DVD player, model DRC282. I haven't had much luck with a couple of universal remotes. Any help would be appreciated.
Just try a code search process. Sometimes it might help you:
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
May 12, 2012 | Televison & Video
Need acess code to program a remote
Hello
What is the brand name and model number of your remote control? different remote controls have different setup codes for the same device. Send me the details of your remote control. OK.
Oct 15, 2011 | Philips DVP642 DVD Player
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Program remote to vcr/dvd player
you can enter your remote number here for the code list:
http://www.urc.philips.com/
Feb 16, 2009 | Sanyo Televison & Video
I need a code # to program my Universal RCA remote for my Prima TV and my DVD player
I own a One-for-All universal remote, and my booklet says the setup code for a Prima TV ( without a built-in DVD or VCR) is one of the following numbers: 0761, 0783, 0815, 0817. I can not guarantee these numbers will work with your remote, but it is worth a try.
I assume your DVD has been attached separately, and not built into the TV. In some cases, you might not need an additional setup code. Once the TV has been turned on, you simply push the DVD button on your remote, to activate the DVD. The instructions which came with your remote and your DVD should provide you with more details. If the instructions indicate that an additional DVD setup code is required, then please respond by telling me the brand name of your DVD.
Jul 04, 2008 | Televison & Video
Help with dvd player DRC282 remote code
I purchased this same DVD player (DRC282) and none of my universal remotes worked for it. Since I was lucky enough to buy one without a remote, I ended up purchasing an RCA universal remote (RCR3273). Once again, none of the codes worked so I had to unplug the unit for 5 minutes, then plug it back in and hold the Standby button for 15 seconds to return it to it's factory settings. I manually searched through 71 codes before I found a match but the play, pause, rewind and many other functions failed. I tried again skipping over 71 and found the right code at 115 tries. That one had all the functionality I needed. You should try the same strategy with your Comcast universal remote. Skip the first match and keep going until you hit the second manual match.
Apr 09, 2008 | Televison & Video
Need Remote Control Code
All these codes are used by Teac
Hopefully one will work for you
0037
0512
0455
0264
0009
0412
0349
0041
0000
0278
0037
0081
0307
0609
0110
0717
Mar 08, 2008 | Televison & Video
Is it multiregional
Sony are probably the most protective manufacturer of this kind of information. All manufacturers carrying a DVD logo are obliged to say "no" but will normally intentionally leak this to boost sales, particularly in non-US areas.
But try this:
  • Press the DVD button
  • Hold down the Magic button until the unit performs a double LED flash
  • Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option 3. On your DVD recorder, using the official Sony remote, select the Setup option 4. On your DVD recorder, using the official Sony remote, select the Options option 5. On your DVD recorder, using the official Sony remote, select the Command-Mode option 6. On your DVD recorder, using the official Sony remote, select the DVD1 option 7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover 8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player 9. Program your OneForAll remote with the following instructions:
  • Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
  • Press the Magic button once
  • Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
  • Press the 1 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
  • Press the 2 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
  • Press the 3 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
  • Press the 4 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
  • Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode 15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 16. Your DVD player should show the words TIMER OK 17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 18. Your DVD player should return itself to Standby mode 19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Nov 27, 2007 | Sony DAV-S500 System
Televison & Video Logo
665 people viewed this question
Top Televison & Video Experts
