Question about Clover Corporation CDR-4070 Video Recorder
The box is making a sound like its rewinding.
  • 148 Answers
Sounds like the harddrive is going bad , its the only moving part inside.
Posted on Oct 11, 2010
  • Bill Collier Nov 03, 2010
    I have this model also. Mine has made the "rewinding" or whirring sound since the day I turned it on. Still working years later. Free PDF manual can be found at: http://www.cloverusa.com/data/goodsimage...
Rewind crank is loose on my Minolta XG 1 Film SLR
There is a spring in the bottom of the rewind knob that holds the crank, and it sounds like it has dislodged or the plastic rewind knob is cracked (try small amount of super glue for this). You can rewind the knob off the shaft (open the film door and put something in the rewind fork to keep the shaft from moving) and then turn the rewind knob opposite the direction of the arrow (if the arrow says turn clockwise, then turn counter clockwise). This will allow you to remove the rewind knob assembly and check it for damage, etc. Also, there is a small shaft at the end of the crank. Make sure it is not bent.
May 16, 2014 | Minolta Photography
Rewind sound when switched from auto focus to manual focus
Probably a problem with the af/m switch so that even though switching to manual moves the connector out of the way (pulls it into the mount) the af motor continues to run. Remover the bottom and then the front cover and check the switch.
Jan 23, 2014 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Nikon f601 won't rewind
needs repairing at a qualified shop
Sep 06, 2012 | Nikon F601 35mm SLR Camera
The battery in my Minolta Maxxum 7000 died while rewinding. I replaced the battery, but nothing happens and the rewind-button/slide is stuck. How do I reset this slide, so I can rewind my film?
Sorry to hear you're having troubles with your Minolta. First thing I would do is make sure that the batteries you put in our good and that you do have power coming out of that battery box. He didn't mention whether the batteries had corroded or if there had been any corrosion previously. The rewind button on this camera will not reset until the camera again advances. In other words it is an automatic release on the camera fires the first time after a rewind. So as an beginning answer to your question I would check the batteries again make sure that all contacts are absolutely clean and as you may have noticed the battery boxes on the Minolta do pivot. The contacts under the pivot points also have to be clean. If you checked all of these issues and you're still having problems please feel free to e-mail me at, Dave@advancedcamera.com.
Thank you good luck
Aug 10, 2011 | Minolta Maxxum 7000 35mm SLR Camera
Hi I have recently got a Hitachi HDR255 250gb Freeview + recorder. The problem i've got is that when I am in live Tv Mode and I want to rewind it will only rewind back about 5-10 seconds and then...
Jim, it may say it on the box, but as i found out today, this recorder does not allow the rewinding of live TV. In fact, it seems that few freeview+ boxes do, even if the box says so. I had to return a hdr255 to Argos today for this very reason.
Feb 20, 2011 | Televison & Video
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
My deluxe elite rewind vacuum spits out dirt
The elite rewind does not have any fancy features. This sound like you have a blockage in the foot or base of the vac. remove the bottom cover to look under. Also check the hose, it can be in there as well.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 16, 2010 | Vacuums
Bobbin will not rewind
SE270D. Lift the bobbin and reposition, making sure it is down against the pin.
If this is not the problem, a Sidewinder Bobbin Winder (auxiliary bobbin winder sold with most sewing notions) is a lot cheaper than taking the machine in for service.
Mar 14, 2010 | Brother Sewing Machines
I finished taking pictures but it didnt rewind. did i load the film wrong? or did the batteries die? or whats up
Have you tried taking just one more pic to see if that triggers the rewind? If that didn't work, most film cameras have a rewind button. Usually on the bottom of camera. If you still can't get your film to rewind, take camera to your nearest photo finisher. They should have a dark box; they can remove your film manually.
Feb 18, 2010 | Canon EOS Rebel K2 35mm SLR Camera
A pinging sound whenever i try to record something or rewind the cassette
It sounds like there's a problem with the tape loading mechanism. The first thing you should try is seeing if the camcorder will allow you to run a head cleaner through it (probably not the problem, but something everyone should do regularly, but most people don't). If that's not the issue, then it's probably something that you can't fix yourself. You should have information in the box that tells you where to send it to for repair. Good Luck.
May 24, 2007 | Sony Handycam DCR-TRV147E Digital-8...
Clover Corporation CDR-4070 Video Recorder Logo
77 people viewed this question
Top Clover Corporation Televison & Video Experts
Are you a Clover Corporation Televison and Video Expert? Answer questions, earn points and help others
