Question about Kenmore Dryers
Dryer is overheating - Kenmore Dryers
  • kevin  foster
    kevin foster Oct 11, 2010
    there is a thermostat that most likely needs to be replaced.are yoiu goi9ng to try to repair it yourself?
  • Kenmore Master
  • 7,482 Answers
BE SURE TO UNPLUG YOU MACHINE FROM THE WALL BEFORE YOU START ANY WORK.
Your problem could be a Thermostats/Thermistors malfunction.
But this overheat condition also could be caused by a buildup of lint in the duct work, or a faulty blower motor/fan blade.
This will cause an overheat condition that you describe.
You will have to locate the air tube that is going to the dryer drum. Some general area the heater is located.
Is also where you will find most of them.
They normally are round/oval shaped and have two wires connected to them. Take off the wires and with an Ohm meter set to "continuity" check your thermostat/thermistor.
If you have continuity across the terminal it is not faulty.
Be sure to check all of the thermostats/Thermistors.
If this is not your problem then it will be the Control board if you have one on your machine.
Look for the fan blade to be in the air tube going to the dryer drum.
This is a FREE answer, Please Rate Me
Posted on Oct 12, 2010
Thermal limiter maytag bravos dryer
a thermal limiter is a safety switch designed to keep a dryer from overheating, by either shutting off the heating element or the dryer itself if activated. They don't normally need replacing (unless you know your dryer overheated and activated it). If you have no heat in your dryer, chances are you have a bad heating element--the most common dryer problem
Jan 01, 2013 | GE DSXH47EGWW Electric Dryer
Blowing out cold air
That could be your heating element OR one of the components installed for safety reason's All dryers have limits which trip if their is an overheating problem. Overheating is cause mostly bu air flow blockage. Rarely by the heat control itself. But you cannot rule that out if the dryer is clear of lint and junk. Your basic service manual and more is on my dryer page: DRYER PROBOS
Sep 21, 2012 | Dryers
Dryer overheated now does not start
the most common cause are that one of the high limit thermal fuses has gone bad. they need to be checked for continuity and the one that has not continuity needs to be replaced
May 18, 2010 | Whirlpool GEW9250 Electric Dryer
DRYER WILL NOT SHUT OFF. CONTINUOUSY RUNS AND IS OVERHEATING.
The control board regulates the timer functions, yours may have failed
Nov 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire dryer is overheating
Sound like the limit switch on the dryer is faulty and needs to be replaced. Hoped this helped
Mar 14, 2009 | Frigidaire Dryers
OVERHEATING DRYER
First make sure the vent is not blocked relieving air flow in back for examlpe remove exhaust hose and let it run with a window open for ventalation of course and let me know if this stops the problem
Jan 31, 2009 | Whirlpool LER4634J Electric Dryer
LG Dryer overheating
check vent outlet out side house is it blowing out air.
Dec 24, 2008 | LG DLE5977 Electric Dryer
Clothes dryer motor overheating
Have you repalced the thermostat?
Apr 28, 2008 | Washing Machines
Dryers Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
