Question about Spirit ® XT175 Folding Treadmill
The treadmill has to be reset and unplugged before it will start to move the belt. The visual displays and fans work but the belt will not move. The machine also will stop after you run about 15 minutes
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 06, 2013 | Exercise & Fitness
Why is facebook not working
You must reset the treadmill, and see if you have Internet and if your router is working o.k
God bless you
Instructions 1.
    • 1
    • 3
    • 4
    • 2
Nov 13, 2013 | Exercise & Fitness
Nordic track A2350 treadmill, I found this unit with lights blinking this afternoon, so I unplugged for 1hr and when plugged back in the only thing that happens is the red iFit logo comes on. What can I...
reset the treadmills, follow the steps and fix it.
God bless you
    • 1
    • 3
    • 4
    • 2
Oct 18, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
After attaching key all lighs come on but none of the buttons work except foe pulse feature. also belt won't move.
rests the treadmills, follow this steps and fix it. God bless you
replace old batteries ( if your system has batteries, clean the contacts batteries from oxide, dirty, etc) put a new one. Tight the ribbon cable inside the display board+tight the upper and lower connector too.
    • 1
    • 3
    • 4
    • 2
Oct 18, 2013 | Nordic Track C2255 Console (treadmill)
Treadmill displaying temperature over for an mbh fitness.what are the possible causes?
The cause of this problem is because your powerboad need big power (Amp) to turn the motor (and the belt) This usually happens if your treadmill belt is not lubricate well or needs change. So, first try to lubricate your treadmill belt with silicone oil and be sure that treadmill deck is clean. If the problem continues you must change your treadmill belt.
Greetings from Greece
Oct 18, 2013 | Horizon Fitness Exercise & Fitness
Horizon t207
1.
    • 1
    • 3
    • 4
    • 2
Oct 08, 2013 | Horizon Exercise & Fitness
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
1.
    • 1
    • 3
    • 4
    • 2
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
Belt won't move
does is just not move when you're standing on it, or not even move when you're not standing on it. It may be a simple belt adjustment or if the motor is running but there's no track movement you may be looking at a loose/broken drive belt. Take the cover off, start it up and look at the motor/drive pulley assembly. If the motor turns and the front roller doesn't, tension the drive motor by moving it back. If the front roller turns but the track doesnt, do a track adjustment as per your users manual.
May 26, 2010 | Proform CrossTrainer Treadmill
Spirit ® XT175 Folding Treadmill Logo
52 people viewed this question
Top Spirit Exercise & Fitness Experts
MrJunk
Level 1 Expert
Electro Med Services...
Mister G
Mister G
Level 1 Expert
Are you a Spirit Exercise and Fitnes Expert? Answer questions, earn points and help others
