Question about Toshiba 56HM195 56" Projection HDTV
The power comes on but no light no sound. Afrter about 10 sec the blue light is still on but the amber light is flashing note:it is not the bulb
  • 755 Answers
Sounds like a popped power supply.
You can either get schematics and pull the board yourself and look for the swollen caps or take it out and have a shop check it out.
If you do it yourself look online in chat rooms from someone who already fixed this model and what caps they replaced. Its a real timesaver. Also, if you have the PS part number you can go on
Ebay and price up a refurb. I see some for around 50 bucks. Not too shabby eh?
Posted on Oct 11, 2010
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Wont start up
Check physical connections first, check monitor cable if securely plugged in and then check power light of monitor. If power light on monitor is amber or yellow it means that monitor is not getting a signal from cpu/ tower. Try to do a power drain on the computer, remove power cable at the back of the computer and then press and hold the power button for 10 secs, after that plug in power cable again and restart the computer.Check if there is any connection if not then try to use another monitor, a known good one. If you get a video from another monitor it means monitor is already defective.
May 15, 2010 | HP Pavilion a1610n PC Desktop
Amber light on in box and monitor no pics at all
if the Box (System Tower) is Flashing AMBER,seems to be Powersupply is gone.unplug all the cables,press the power button for more than 10 sec then put all the cables and try to turn on
Jan 02, 2010 | Computers & Internet
Blue light flashes no power or sound then comes on for a second then off again
i listened to a few people and took a shot at the bulb that was the problen i found 1 about 10 miles from my house at 189 witch was a little high but it was done in a few hours, thanks
Apr 18, 2009 | Televison & Video
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Hitachi 55" when I turn it on the screen is blask and no sound.
first step to take:
refer to the user's manual to find: How to replace the lamp?
and second replace the lamp. www.andrewselectronics.com. prefer original ones.
Mar 29, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Toshiba 56HM195 56" Projection HDTV Logo
290 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
