Question about Craftsman Convertible 25cc. Gas Line Trimmer
I replaced the fuel lines and now it won't stay running
    President:
  • Craftsman Master
  • 1,545 Answers
It is possible that some debris/old broken up fuel line entered the carburetor at some point. The carburetor should be removed and inspected and cleaned. Pay real close attention to the fuel pump side of the carb (where gas first enters) as there is a very small fine mesh screen that traps most particles and holds them there to be cleaned. Also be aware that the diaghragms inside the carburetor eventually become faulty and need to be replaced to restore the unit to the original running condition. Other times, all that is needed is about 1/4 turn or less of the L or H speed screws on the carburetor.
Posted on Oct 11, 2010
1997 geo prizm won't stay running sputters and dies upon acceleration
, like it ain't gettin fuel; probabley a fuel pump or fuel injecter, fuel filter, something along those lines. Start with the filter its cheapest
Jan 13, 2013 | 1997 Geo Prizm
Replaced all fuel lines and pickup fuel filter. but won't stay running without choke.
Take the carburetor off and clean it and check and replace any air filters you may have. Can't say that this will fix it ,but it is a starting point for you. Hope it works and good luck.
Dec 01, 2012 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Idles but won"t stay running
Does it die or bogg down when you accelerate the motor? That is a symptom of a lean condition. Check your fuel filter, fuel lines ( if the filter has come off the end of the fuel line and is laying loose in the tank then the fuel lines need to be replaced, also replace if the fuel lines are stiff or discolored ((brown)), or the carb needs to be adjusted or rebuilt.
Nov 05, 2012 | Troy-Bilt Garden
I have a husqvarna 4623 zero turn and when I would pull up the pto the mower would die. I replaced the fuel filter and now it won't even stay running
Most likely the battery isn't holding enough charge which is why the PTO won't engage.
Likely you have air in the fuel line/fuel filter which lets it run for awhile then it fuel starves.
Oct 30, 2012 | Husqvarna Garden
Won't stay running
sounds like carburetor is clogged or has something in the jets or possibly fuel line or tank is clogged. check fuel tank and line to make sure fuel flows easily then carburetor cleaning and rebuild may be required
Aug 24, 2012 | Mtd 22" Yard Machine Push Mower
My three wheeler doesn't stay running when it starts. What could be the problem besides the fuel line . just added a fuel filter on it but she still won't start or stay running at times. Co
The damage is already done before you put the fuel filter in. (dirt in Carb)
Remove your carb and dissesemble it and clean everything out and then put back on the machine with FRESH gas and you will be fine...run like a top !
Jul 06, 2012 | Cars & Trucks
1993 Honda CBR 900 RR Fireblade won't stay running with the choke off.
Hi, Michael and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Won stay running with choke off CBR Forum Enthusiast forums for Honda CBR...
http://www.fireblades.org/forums/general-discussion/33325-howdy-folks-1996-cbr900rr-cold-start-problems-please-help.html
Honda CBR900RR Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR900RR Fire Blade Owner Manual
Jun 05, 2012 | 1993 Honda CBR 900 RR Fireblade
Pw50 fires but won't stay running
Hi, Jj9871 and the usual suspects are:
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
pw50 won start please help
My Son Has Yamaha Pw50 That Will Start But Won Stay Runn
https://books.google.com/books?id=ozV8-Aer4N8C&pg=PA84&dq=pw50+manual&hl=en&ei=TCS2TcbdJ4PW0QG0z9jmDw&sa=X&oi=book_result&ct=result&resnum=1&ved=0CGUQ6AEwAA#v=onepage&q=pw50%20manual&f=false
OEM parts for Yamaha
Yamaha PW50 Owner Manual
Apr 14, 2012 | 2004 Yamaha PW 50
Won't stay running. its like its starving for fuel
REPLACE FUEL FILTER AND AIR FILTER, FIRST.IF ENGINE STILL WONT STAY RUNNING COULD BE FAULTY FUEL PUMP.CLOGGED FUEL INJECTORS.
Jul 10, 2011 | 1990 Chrysler New Yorker
Craftsman Convertible 25cc. Gas Line Trimmer Logo
224 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
