Question about Kitchen Ranges
Fridgedare electric range door lock
Trible here. Thank you, your answer did help. My husband took off the doors and raised the top. He was able to unlock the door from there. I"m new on this site and don't know where to go to rate you. You were courteous and helpful which was more than I can say for the first answer I got, chastising me for writing a second email because I did not understand what to do. He complained he had too many to answer to be bothered with a second one.
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
just go to my Solution# select/click on Fixya as shown below:
Click HERE to go directly to the page. My solution was on #2.
Thank you.
Posted on Jun 01, 2008
I have a flat top fridgedare stove.I accidentally hit the clean button and opened the door but the latch had locked now I cant close door and oven wont come on and it just keeps flashing loccked.It doesnt...
The latch is solenoid operated. remove power from the stove (unplug or breaker). That should release the lock. Close the door and power back on. Hopefully all will be reset.
Aug 03, 2014 | Kitchen Ranges
Whirlpool Electric Range Model # RF369LXPB. Self cleaning function does not work. A code displays after self cleaning function has been on for about 3 minutes. The code is F5EO. What does this mean?
Hello, Thank You for using FixYa. I will be helping you today.It means the door lock and door switch dont agree. Check the door switch does the oven light go on and off? does the door lock? It is either the door lock or oven door switch that controls the light.
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Whirlpool RF369LXPQ Electric Kitchen Range
Kenmore 95024 Electric Range The self clean cycle Door stuck shu
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Kenmore 95022 / 95024 / 95029 Electric...
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
Oven door locked
Hi H.Fried,
Happy to help you!
But I see that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Aug 14, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Electric range
Yes, like I said, unplug the range from the wall socket. There should be a circuit breaker that corresponds to that particular socket. Switch that off as well, and wait about 15minutes. After that, please plug the range back into the socket and turn on the circuit breaker. That should reset the device.
If that does not work, you can either try calling the manufacturer, or get a repair guy to come and physically unlock/replace the interlock assembly.
PS, if you have more queries, please reply to this same post, you need not start a new post, or else I may get confused, considering the number of posts I have to handle :) If you reply to this same post, I will have an idea about the issue and you will not have to repeat things for me again :)
May 28, 2008 | Kitchen Ranges
Door lock
dl meand door lock. A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error. Potential Causes ? Door Lock Mechanism broken or removed from the Door ? Check Door Lock/Switch Assembly ? Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) ? Door Lock/Switch Assembly Failure Replace failed component.
Sep 22, 2007 | Kenmore Elite 45986 Front Load Washer
Oven Range Door Does Not Lock
Jocalo, Did you set up the time for cleaning and pushed the "start" button? Gendos
Jan 03, 2007 | Whirlpool RF378 Electric Kitchen Range
Kitchen Ranges Logo
47 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
