Question about Maytag Centennial MVWC500V Washer
I have a Maytag Centenial washer, model mvw c500vw1 The cold water barely trickles in, Hot is ok. I cleaned the screens and have great water flow hot and cold at the hose end where it connects to the washer. I am thinking it is a bad water valve / solenoid. First, how do you get the back of the cabinet off to access the valve, or is there another problem?
catriver
  • 878 Answers
SOURCE: NO COLD WATER
Ray, a little additional information to the excellent info Zeusfaber gave. The inlet valve is 120V. If you want you can take a cheater cord and see if the valve is funtional. If it works with 120V to it, you may have a problem with the automatic temp. control board. This board mounts directly behind the timer, if your model has it. (Automatic temp settings). I've seen it where if this board fails, you get a hot fill only. Carefull with the test cord, live juice there...Catriver..post back.
Posted on Mar 05, 2007
jackiaria
  • 350 Answers
SOURCE: Water flows in cold side of water valve and out hot side valve
It seems unlikely that something went wrong just from moving it unless it got banged up!
It sounds like you may have stripped the hot side.
I'm assuming the water is going in the cold side and out the hot side and out the back.
If this is so and you are happy with just cold water try this:
Go to a Plumbing Store and buy a cap for the leaking intake...if it still leaks you can try soldering the two together!
I hope this was helpful.
Good Luck!
Posted on Jan 20, 2009
  • 37 Answers
SOURCE: Maytag Legacy Series Top Load Washer model
Have you tried cleaning out in and around the inlet on the washer (where the cold hooks into the washer)? We had the same problem. When I removed the cold water hose, I cleaned out the end of it and the inlet on the washer-there should be a small screen on the washer side. It does it on cold because with the hot, a hot water heater filters most of the debris out of the water before it comes out and the cold water is not filtered. Hope this helps!
Posted on Apr 03, 2009
mastatech
  • 478 Answers
SOURCE: Maytag neptune washer wont fill water
It is very possible for it to be a valve failur as these machines have a temperature control incommon, It recieves voltatge through the temp control.
Posted on Jan 10, 2010
marka19
  • 1430 Answers
SOURCE: Maytag A7300 (purchased 1992) is very slow to fill
The water inlet valve is failing or the screens in the valve are clogged up. The valve is most lokely not opening all the way. You will need to replace it. They are inexpensive and easy to replace. Here is a link that should help
http://appliancehelponline.com/topwaterinletvideo.html
Posted on Jun 21, 2010
Silt, sand, something from deep water well has migrated past exterior washer hose screens into washing machine. Older Kenmore HD Series 70 top loading washer. How to fix?
probable but unlikely
the control valve for the water ( hot or cold ) has a diaphragm in the main flow with a small hole in it to act like a pressure regulator
so when the solenoid shuts off the water , water flows through that small hole and locks the diaphragm firmly on the seat
I suggest that the low flow is because that diaphragm has been compromised and is not opening correctly for full water flow
take it apart and clean it out or replace it
Feb 04, 2018 | Kenmore Washing Machines
Very little cold water flowing. Hot is fine. Checked lines--all flowing great.
Remove the cold water line from the rear of the washer.
Remove the filter screen from the water valve and clean it.
A straightened paper clip works good to remove the screen.
Replace the screen after cleaning or you will damage the water valve running with no screen.
Jun 15, 2011 | Maytag Washing Machines
The cold water trickles. There is a "good" flow of water (hot&cold) to the machine yet, the cold water trickles out on any cold setting. The hot water has great flow. What could be the answer?
Sounds to me like your inlet valve is gunked up. You will need to replace your inlet valve. I would also check your hoses first to make sure the cold water hose does not have a screen on it that is full of calcium deposits. Hope this helps _MJ_
Aug 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Hot water barely trickles into washing machine
Check the hose at the end where it connects to the washer (the inlet valve unit). There may be a screen there also that needs to be replaced or cleaned. If not then the hot water solenoid valve is probably gunked up with the same type of stuff you found in the filter screen. You may be able to clean it enough to get it to work but replacing it is just as easy and not very expensive. (Even cheaper see if you can salvage one from an old machine at the dump or that someone has left at the curb--the units are very standard across many manufacturers in the tU.S.) Both the hot and cold water valves are in the same unit.
Jul 23, 2009 | Admiral AW22 Top Load Washer
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Maytag Legacy Series Top Load Washer model SAV515DAWW When filling, the cold water just trickles in and takes a long, long time to fill. When I unscrew the hose from the washer and turn the water on it...
From what you have said, you may have a bad solenoid in your water fill valve. it's the rubber piece under the debris screen. if you can get that out and replace it, you'll be golden.
Feb 22, 2009 | Maytag Legacy Series Top Load Washer
Hot Water won't fill
I like to put the hose over in the tub and run some water just to eliminate plumbing problems from that point back. Then, I check the inside of the water valve where the hose connects which you have done. If all this is ok the only thing left is to replace the water valve. I have had some success taking the water valve apart and cleaning it out. About 2 out of 10 will start working but most require replacing.
Jan 24, 2009 | Maytag Washing Machines
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
GE Washing machine cold water barely dribbles in
Yes remove the hose from where it connects to washer look inside water valve and remove plastic screen with needle nose pliers Without damaging it. Also make sure that it gets back in proper as the valve will be damaged without it.
Jan 19, 2008 | Washing Machines
Maytag Centennial MVWC500V Washer Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
