Question about Dryers
My clothes are catching between the drum and casing(?), the drum seems to be loose. My dryer is a GE profile/prodigy
    Genius:
  • 1,028 Answers
Suspect front tub support/bearing ring worn remove top by removing screws under front edge of top lift top 1 screw each side of front on inside front ring attaches to front panel look for worn plastic ring and pads
Posted on Jun 01, 2008
Oldfixer is right. My clothes were catching, plus I was getting grease type streaks on our clothing.
Opening the top and front of the dryer revealed pieces of the plastic ring broken and the top portion of pad completey disintegrated.
We received this dryer from someone who got a new set, and they didn't mention that the dryer was having problems. :-(
Posted on Jan 11, 2009
My dryer just stopped working. We did a couple of loads today and on my start of the second load, I put the clothes in the dryer and turned the START switch, but all you hear is the dryer trying to start....
It is your motor. Here is a trick to try to see if that is the case. Get some tape and put it over the door safety latch. Spin the drum as you press the start button, if the dryer takes off then it motor.
May 01, 2011 | Dryers
Our dryer squeaks very load, and the drum just started vibrating. very scary. can u help?
The dryer drum sits on a gasket. Usually you can pop off the top and see if the gasket has failed. If the drum has slipped you may be able to re-seat it. If it has failed it will should be visible.
Mar 20, 2011 | GE Profile Prodigy WPSE4200A
We have a GE Prodigy clothes dryer that makes a very loud sqeacking noise when it runs
sounds like a rear drum bearing thats gone bad very common with these units, the front bearing and slides should also be checked for wear at the same time,to replace bearing in back drum has to be removed completely. if your handy with tool and have and afternoon to kill its not that bad ,just rember to UNPLUG UNIT BEFORE ANY WORK
Aug 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
My dryer is making a scratching noise like something is stuck behind the drum toward the front of the dryer. Any help?
The drum has a seal between the drum and the front panel of the dryer. You would need to remove the top then the front panel to gain access to replace or maybe clean the seal
Mar 30, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
GE dryer won't start up - sounds like the drum is stuck.
unplug it,open the door and look up.you'll see two screws,take them out and remove the top panel,then look around three or four inches down from the top and removetwo more screws,one on each side,this is harder than most dryers to work on,not much room to reach under the drum to remove and reinstall the belt,there's also one more screw down on the right hand side below the drum that has to come out also, just remember how you took it apart,if you start it and hear a loud humming sound that's the motor,hope this helps you
Feb 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
My GE Profile Dryer is still operating but produces loud intermitent noise as the drum rotates. What can I do to eliminate the noise?
It sounds like you may have a bad bearing in the back of the drum. That model rotates on a sort of ball and socket type mechanism. You may be able to lubricate it if the noise is just squealing/squeaking. If it is more than that, you'll probably need to replace the bearing mechanism. If you lube it, use a heavy weight lube that is rated for high heat (I've used brake caliper grease.)
Jan 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
Dryer blows hot air and tumbles; but condensation builds on door and clothes don't dry
SOUNDS LIKE YOU HAVE AN EXHAUST PROBLEM LIKE THERE MUST BE SOME KIND OF RESTRICTION
Dec 16, 2009 | GE Profile Prodigy DPSR513GA Dryer
GE profile prodigy - dyer
hi. the vent inside the dryer needs to be cleaned.you must live in a warm climate. clean all air vents inside the dryer, and out. thanks the appliance doc
Oct 04, 2008 | GE Profile Prodigy WPSE4200A
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Jan 29, 2008 | GE Profile Prodigy WPSE4200A
Dryers Logo
274 people viewed this question
Top Dryers Experts
