Question about AEG U7101-4 Electric Double Oven
Oven does not work with ventitherm fan opereated cooking option. It does not get hot.
  • AEG Master
  • 3,463 Answers
I suggest you fit a new fan oen element, located at rear of oven compartment behind a remoeable cover.
Posted on Oct 11, 2010
Why does the fan not work in main oven while cooking, book says fan assisted oven, only see it working on rapid preheating to heat oven first. is it meant to work while cooking in main oven
A lot of ovens have a convection option, and the fan will only work in this position. Otherwise, just rotate your pan halfway through, like we always did.
Dec 27, 2014 | Ovens
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
Bosch oven temp control
If the temp control works for all other settings, it is working for hot air grilling as it using the same stat....when hot air grilling function is used the grill comes on and when it reaches temp the element switches off and the fan switches on. Once this has happened the element and fan will alternate during the cooking period. The fan and element DO NOT operate at the same time.
Mar 23, 2013 | Bosch Ovens
My electrolux EOD 3360 bottom oven is getting too hot. The oven temperature light stays on even at the lowest setting or defrost setting. The inside of the oven is literally roasting hot, and anything I...
1 . If your ELECTROLUXfan oven is getting warm but takes a very long time to cook or is burning thefood more on one side than the other, then you need to check if your oven fan motor isworking you will see the blade turning fast if it is ok. if the element isheating but the fan motor is notblowing the heat into the oven then you need To replace the oven fan motor is alittle more expensive and a bit more involved.
2 . If you have the opposite problem i.e. your ovenis over heating and burning everything then you will need to replace your ELECTROLUXoven thermostat
3. A quite common and easily overlooked answer isif your ELECTROLUX oven is not working at all i.e. noheat and no fan then the chances are that someone has put the oven timer into AUTOmode, simply put oven back to MANUAL mode and all should be working again.
Mar 22, 2011 | Electrolux Ovens
I saw sparks? or small flame on back wall behind fan inside oven
It sounds likely that the fan motor is faulty,more so if the oven is heating to some extent.
You should be able to see or hear if the fan is working or not
Hope this helps with your prob.
Nov 26, 2009 | Gaggenau EB 270/271 Electric Single Oven
720 EF Fan oven fan making a scrreching noise now
It could be that cooking residue has run down the inside of the fan cover and it is restricting the fan movement. The fan cover is held on by four self tapping screws, one on each corner. Remove the cover and have a look to see if there are any rub marks on the inside. You should be able to remove some of the gunge by soaking the the whole cover in hot soapy water. If that doesn't work, buy the Lakeland brush on oven cleaner - that definitely works - you can use it on all of the inside of the oven. Whilst the cover is off, briefly turn the oven on to see if the fan still makes the same noise. If it does, it looks like the fan bearings are suspect and a new fan may be required. If not you have found the problem with the cover. Page 37 of the Handbook tells you how to replace the circulating fan.
Sep 23, 2009 | Stoves 720EF Electric Double Oven
My CDA fan oven will not get hot
Ok , classic example of a fan oven element blowing, take the cover off inside the cooker held on by 4 screws so you can see the round element, you should be able to see where its blown a big hole.
replace element
( make the cooker is turned off of course)
Sep 18, 2009 | Ovens
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
DeLonghi ESS601 electric oven
We just moved in to a place that has this oven, if you use the setting with the fan with a circle round it, seems to get hot! Don't know what the other is for though!
Hope it helps!
Pete
Jun 20, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Fan on during cooking
djpat, in looking at your schematic, it shows that the cooling fan will be on during bake and broil operations as well as cleaning. So this would be a normal operation. Catriver.
Dec 24, 2007 | Whirlpool RBD245PD Electric Double Oven
AEG U7101-4 Electric Double Oven Logo
155 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
