Hello, I have Vista and everytime after my computer boots, I get a pop-up that states: KBD EXE is not working. What is this and how do I fix this problem? Thanks, Pat
  • 2,229 Answers
Assuming that once it starts everything is OK and the computer functions normally, try this:
Right above the start ball, there is a command line. In that white space, type MSCONFIG.
When the window opens, click on the startup tab. Find the KBD.EXE command and uncheck the box next to it. This will tell it not to run.
Now restart the computer. In Vista you'll get a message that a program was blocked. Tell it to run the blocked program. When it opens (the system configuration utility), check the little box that says not to display it again. Now everything should work.
Posted on Oct 11, 2010
Hello I bought A4Tech G7100 keyboard & mouse set, after 3 days my keyboard is no more working i tried another cells but no effect, the last suspicious activity i saw was the stream writing means if i...
NO PC stated, why post to lacking that key fact.?
even the mouse/kbd is not HP.
but are posted to Compaq /HP.
its a wireless keyboard, and like ALL things like that
has batteries, or it can possibly work.
the mouse batteries.
The keyboard batteries. are bad. replace them..
and drivers to make the unstated PC work with this wireless module.
if panicked. use a real keyboard, USB, any one you find works
and uses NO BATTERIES to do so, same with the mouse.
that is step one,
step two are the drivers.
if running xp or vista the drivers will not come from Microsoft
as they once did, so getting them will be hard.
NOW ! XP is a dead product.
but again no PC stated, no OS stated, no real help here, full.
Nov 04, 2017 | Compaq Keyboard
Tip
Repairing Windows Vista using bootrec.exe
Bootrec.exe tool can be used in the Windows Recovery Environment (Windows RE) to troubleshoot and repair the following items in Windows Vista:
  • A master boot record (MBR)
  • A boot sector
  • A Boot Configuration Data (BCD) store
To run the Bootrec.exe tool, you must start Windows RE. To do this, follow these steps:
  1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
  2. Press a key when you are prompted.
  3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
  4. Click Repair your computer.
  5. Click the operating system that you want to repair, and then click Next.
  6. In the System Recovery Options dialog box, click Command Prompt.
  7. Type Bootrec.exe, and then press ENTER.
Bootrec.exe options
The Bootrec.exe tool supports the following options. Use the option that is appropriate for your situation.
/FixMbr Use this option when you must resolve MBR corruption issues, or when you have to remove non-standard code from the MBR.
/FixBoot Use this option if one of the following conditions is true:
  • The boot sector has been replaced with a non-standard Windows Vista boot sector.
  • The boot sector is damaged.
  • An earlier Windows operating system has been installed after Windows Vista was installed. In this scenario, the computer starts by using Windows NT Loader (NTLDR) instead of Windows Boot Manager (Bootmgr.exe).
/ScanOs Use this option when there are Windows Vista installations that the Boot Manager menu does not list.
/RebuildBcd Use this option when you must completely rebuild the BCD.
Note: It will work with all windows Vista versions
on Mar 03, 2010 | Microsoft Windows Vista Ultimate Edition
(LOGITECHDESKTOPMESSENGER.EXE)
Hello marchits2002, please have a look in your Startup and disable the filename you stated above from running on startup.
To do this - Press Windows Key + R (to open the Run Dialog), then type MSCONFIG.EXE and press Enter.
You can now see the fourth tab called Startup, have a look at the list and uncheck any startup items you don't find necessary.
Apply the changes and restart computer. Done.
Mar 19, 2010 | Computers & Internet
Lexmark registration reminder pops up everytime i
Hi
Not sure but if you go into the add and remove in your pc it might be in there just remove that part of it, but be careful not to delete your driver.
All The Best: Pineworks
Feb 02, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
TVAgent.exe entry point not found always pops out. It says: "The procedure entry point PowerReadACValue could not be located the dynamic link library POWRPROF.dlll how do i fix this. please
Hey,
I have the same problem as you and im in the process of fixing it
I researched it and found this...
http://support.microsoft.com/kb/929135 (Note this is for Vista only)
Use the instructions on how to clean boot your Windows and it should work...
Dec 13, 2009 | HP Pavilion dv9000z Notebook
"BOOTMGR is missing"
Find yourself receiving "BOOTMGR is missing, Press Ctrl+Alt+Del to restart" message? Don't stress! Its easier to fix than you think. Here's how:
SOLUTION 1
- Get your Vista installation DVD and pop it into your drive.
- Then restart your computer.
- Set your computer to boot from DVD or CD in your BIOS.
Vista will ask you for language and keyboard layout information, after which you will be asked if you want to re-install Vista or repair your existing installation.
Select Repair. After which Vista's System Recovery Tool will start.
Select Startup Repair and let Vista do its thing! That really is all there is to it!
If that doesn't work try this:
SOLUTION 2
If the previous method does not resolve the problem, you can rebuild the BCD store by using the Bootrec.exe tool in the Windows Recovery Environment. To do this, follow these steps:
- Press a key when you are prompted.
- Select a language, a time, a currency, and a keyboard or another input method, and then click Next
- Click Repair your computer
- Click the operating system that you want to repair, and then click Next
- In the System Recovery Options dialog box, click Command Prompt
- Type bootrec /rebuildbcd and then press ENTER
• If Bootrec runs successfully, it will present you with the installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully.
• If Bootrec cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order shown below: (Remember to press ENTER after each command)
bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
bootrec /rebuildbcd
- Restart the computer.
Detailed tutorial for this trouble : http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
May 10, 2009 | Dell Studio 17 Laptop Computer PC...
Acer Aspire 5100 won't system restore
If you created your system restore CDs when you purchased the system, insert your first CD into the CD drive and boot your computer. This will restore your computer to factory settings. ALL DATA WILL BE LOST.
Apr 02, 2009 | Acer Aspire 5100 Notebook
My computer is trying to configure and load windows photo gallery but it keeps saying I do not have the CD Rom I do not want to load this program I cannot seem to cance it and when I go into remove...
  • Click Start .
  • In the Start Search field, type msconfig, and press Enter.
  • The System Configuration window opens.
  • In the General tab view, select Selective Startup, and remove the checkmark next to Load startup items.
  • Click on Startup TAB
  • Under Startup TAB uncheck all of the Items except Following:-
  • For Windows Vista
HD Audio Control Panel.
HP KBD EXE.
Hp digital imagine - hp all-in-one series.
HPRun.
Hpsysdrv.
HP Total Care Advisor.
Microsoft Windows Operating System.
NVIDIA products.
Symantec Technologies products.
Windows Defender.
  • For Windows XP, do not disable the following startup items:-
Alcxmntr
Atiptaxx
ati2mdxx
Backupnotify
Ccapp
Ccregvfy
HPBootOp
Hpsysdrv
Kbd
LTMSG
NvCpl
ps2
Recguard
VTTimer
  • Click the Services tab, select Hide all Microsoft services, and click the Disable all button.
  • Restart the computer for the changes to take effect.
  • After the computer restarts, a message appears confirming some startup programs have been blocked from opening.
Jul 04, 2008 | Computers & Internet
Explore won't open in Vista (not IE, I mean windows file explorer)
Most likely a damaged or altered registry entry. Clicks start and type
'regedit' and hit <enter>. Expand the keys at left to reach:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Click on this key, then locate the shell string in the right pane. Double
click it, replace the contents with just:
explorer.exe
Click ok, then close the registry editor and reboot.
This will resolve the issue.
Good Luck.
Live, Love, Laugh.
Apr 30, 2008 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
