Question about Acer Aspire 3680 Laptop
Charging I bought my Laptop in Mid June 2007. Within months the Mother Board needed to repair and Now when I plug in my laptop it won't accept a charge until i shove it in with force and keep holding it until its charge which can take hours. How can I get it to stay charged without pushing it in for long periods of time?
    Guru:
  • 1,342 Answers
The ac adapter connector probably needs to be re-soldered or replaced. You will have to have it serviced.
Posted on May 31, 2008
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
I have a HP Probook 4510s, and it won't accept
I'm afraid it looks like the charging circuit on the mainboard is dead and is very hard if impossible to re-work so it looks like it will have to have the m/board replaced.
I was an engineer for Acer and saw a lot of these issues but unfortunately most of them were not repairable.
Sep 30, 2013 | Computers & Internet
Will not charge battery,have bought new battery, continues to go into not charging mode. Gateway model MA7 charger output 19.27v confirmed
If you are not getting any thing when just the charger is plugged in and either no battery or the battery is dead, but the system will run on a fully charged battery. There may be a problem with the motherboard that a DC jack replacement will not help.. some of the traces sandwiched in the mid-plain on the mother board might have corroded away and need to be bypassed .. check my blog for pictures on how this can be done. http://cegeekbook.blogspot.com/2010/07/gateway-ma7-mx6930-no-power-will-not.html
May 11, 2010 | Gateway Computers & Internet
Inspiron 1501 charging problem
should find out why the original charger stopped working in the first place... was it a faulty mother board really. anyway if the ratings on the charger you bought are for that laptop indeed, then it should power up the laptop minus the battery. ofcourse if you put in charger minus battery, dont expect it to show the charging led..just try to power it on
Regards
Feb 26, 2010 | Dell Inspiron 1501 Notebook
A few months ago my Dell Vostro 1500 laptop started saying that my battery could not be detected. I bought this laptop new in October 2007 and did not extend my warranty. I bought a new battery and...
Normally the message means that the battery is bad and needs to be replaced. There is a chance the new battery you got was defective and went bad before its time.
The motherboard can be the problem, although it is not common for this to be the case.
I would try one more battery before thinking about a new motherboard, a new battery is under a $100 where a new mobo is several hundred, and usually this is a sign of a bad battery. If you disconnect the ac adapter and it stays on then it is using the battery, although it is reporting that it cannot see a charge. I would guess the battery malfunctioned and is not being able to be read by the laptop.
Sep 12, 2009 | Dell Vostro 1500 Notebook
My lenovo ideapad Y510 laptop won't charge or turn on.
Less $$ to replace the laptop after you figure in the cost of the motherboard + labor to have it installed.
Mar 20, 2009 | Lenovo IdeaPad Y510 Notebook
Charger plugged in and computer says it's charging...but it's not
Return it! It's a factory defect they just admitted to it online. Call HP and they'll fill you in on the details.
Feb 19, 2009 | HP Pavilion dv6000z Notebook
Shut down problem
The notebook switches off because the battery has not been properly replenished/recharged. probable problem may be with the battery itself, the AC adapter/charger or the plug/jack.
Common causes of similar problems are a loose connection or a cold solder on the DC jack at the end of the laptop. In some instances, it could be the actual charger/AC adapter that may be at fault. This however could be verified with the use of a voltmeter measuring the DC voltage at the output plug. As to the DC jack, it would be more of a concern opening the laptop and exposing the underneath of the motherboard (where the solder are) rather than the actual repair which is soldering. Incidentally, there are cases where the terminals/pins of the DC jack might have been cut off hence a replacement may be required. Perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 05, 2008 | Lenovo 3000 Y410 Notebook
Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
