Question about Motorola Mobility RAZR V3
How to remove/replace motorolarazr screen. Screen lightsup, but no display. Phone will make/receive calls but nothing shows on screen
    Sergeant:
  • 172 Answers
Replace only the flex cable not the screen, browse for motorola razor v3 dismantel on the net
Posted on Oct 11, 2010
Samsung sch-r451c screen shows white when on but will still send and receive calls
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phones
Good luck.....
Mar 23, 2011 | Cell Phones
No display, but i am able to receive incoming calls. Can I get a spare display unit?... Thanks in advance. My model no. is SGH-D900
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 10, 2010 | Samsung SGH-D900 Cellular Phone
My Nokia phobe 6085h changed to a blue screen only. I can view absoultle nothing on it. However I'm still able to receive calls and hand dial phone numbers. How can i fix my phone to regain visability to...
Hi,when a phone displays a blue screen,it means that the screen might have shifted from the position it was or the screen might be damaged and will need a replacement.
Unscrew phone and adjust the screen.If no display that means the screen of the phone is damaged and will need to be replaced.
Have a nice day.
Aug 06, 2010 | Nokia 6080 Cellular Phone
My display shows nothing but a blank screen even though I can still make and receive calls.
In this case where your screen display won't show up then it is time for you to make a troubleshooting and it involves hardware checking specially to the phone LCD screen. In general, your phone LCD display is faulty and maybe it needs a replacement if it cannot be spare. You can take it to a phone service center if you want to but if you want to do it own your own then you need some tools. You need a T9 screw driver to open your phone and it is more complicated than you thought so it is best to take it a service center. They will be the one who find replacement if they your phone LCD is defective.
Good Luck!
Hope this helps...:-)
Don't forget to rate!..Thanks..
Mar 31, 2010 | Sanyo SCP-7050 Cellular Phone
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
Feb 11, 2010 | Nokia N70 Cellular Phone
Phone got wet.
Most likely the screen display had a shortcut. You need to replace it, although it's not cheap. Expect to pay a little less than the full price of the phone.
Next time spend more time drying the phone, you can even use a bowl with rice to immerse the phone and leave it dry for one full day.
Sep 04, 2009 | LG Shine CU720 Cellular Phone
WMC PC and TV no longer communcating by remote
For the remote : try replacing bateries
Device driver : try reinstalling the tv tuner from the device manager.
Please name you model number of ur pc.
Jun 20, 2009 | Dell Dimension 3100 PC Desktop
Compatible bluetooth Phones
Look here:
http://www.magellangps.com/products/bluetooth_maestro.asp
Jan 10, 2008 | Magellan Maestro 4040 GPS Receiver
Cant see any dispaly
it appears that your display has gone bad or there is a display connector problem. If you are tech savvy then open the phone carefully and on proper examination u will find that there is a connector for the display carefully take it off and replace it. Check if it works if not replace the display
Nov 13, 2007 | Nokia 6630 Cellular Phone
Motorola Mobility RAZR V3 Logo
66 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
