Question about Frigidaire Kitchen Ranges
Cook top elements will not turn on, neither will oven elements however clock works and indicator lights turn on with the control. this is a frigidaire electric slide-in range.
  • Anonymous Mar 16, 2014
    Elements only stay on high when cooking
    Genius:
  • 1,073 Answers
Check the electrical connections to the range and the breaker in the fuse box you only have 120 volts to the unit
Posted on May 31, 2008
I have a Smeg Wall Oven Model No SA710X-5. When I turn the cooking selection switch to the desired cooking setting the green light comes on. But when I turn the thermostat switch to the desired temperature...
It sounds like the element is missing one side of the 240v power. One side may always be hot while other side is controlled. A qualified repairman can Start at the element and work backwards. Trace wiring back looking for burned wire, bad connections and connectors, all the way back to thermostat. Check thermostat for continuity (with power off), replace thermostat if necessary.
Oct 29, 2013 | Smeg Ovens
Lower oven will not come on. Top oven and cook top works
Does the oven indicator light come on when you turn the oven on. If it does the oven element or the wiring at the oven element terminals will be faulty. If it does not come on it will most likely be a problem with the oven control thermostat.
Feb 24, 2011 | Ovens
I have a Frigidaire electric oven and flat cooktop that went out. Neither the oven nor the cook top elements heat up. If I turn the element dial slightly, the digital clock lights up (flashes), but...
With the symptoms that you are describing here ...the problem is in the control board... you still have power, but nothing is being told to turn on...the control board controls all of those functions...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Dec 26, 2010 | Frigidaire Ovens
How do i work the grill?
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
Nov 21, 2010 | Stoves 720EF Electric Double Oven
I have recently moved into a new house and the oven settings on all three dials have been wore away and cant see which setting to use for cooking
The control on the right is for temperature,0 to 275 degrees centigrade.50 is about at 2 o, clock and 275 is about 9 o, clock.Middle dial is for the timer.The left hand one is your functions.at 2o,clock is the light.At 3o,clock is conventional oven top and bottom elements heat.5o,clock is the top element for browning.7o,clock is the bottom element for crisping.9o,clock is the infra red grill for small stuff one element.11o,clock is the full grill for all.12o,clock is off.If you need to order the knobs the part no. is 3303563831. cost € 21.36.
Hope this helped.
May 24, 2010 | Electrolux EOB2610 Electric Single Oven
Clock and lights work but cook top and oven do
The clock and the lights run off of 120 volts and the heating elements work off of 240 volts.
It would be safe to say that one leg of the power is missing. Try turning the circuit breaker off then back on fully.
If this does not solve the problem then you will need an electrician to check the plug behind the range or the 'L2' in the range.
Apr 26, 2010 | Bosch HGS435UC Gas Kitchen Range
I have lost my manual for a Simpson Appolo Atlas Stove
call manufactuerer and ask if you can order one or try to do so online
Dec 22, 2009 | Stoves EC500DOA Electric Kitchen Range
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Aid KESC 307 hbs4 electric range control
CESAR, THE OVEN CONTROL IS THE CLOCK,HOWEVER, ON MANY KITCHEN AID RANGES, THERE IS AN INLINE FUSE 15AMP, THAT IS IN THE OVEN CIRCUIT. I WOULD SUGGEST THAT THE INLINE FUSE BE CHECKED FIRST BEFORE CONDEMNING THE CONTROL.
DAVID, THE GLASS TOP ELEMENTS ARE CONTROLLED BY THE SURFACE SWITCH FOR REGULATING TEMPS. THE SWITCH WILL TURN THE ELEMENT ON AND OFF TO REGULATE TEMP. I WOULD SUSPECT THE SURFACE SWITCH(WHAT THE KNOB IS ATTACHED TO) AS THE DEFECTIVE COMPONENT. THERE IS A HIGH LIMIT SWITCH THAT IS PART OF THE ELEMENT. IF IT WAS BAD, THE HOT SURFACE INDICATOR LAMP WOULD BE LIT ALL THE TIME.
THE ELEMENT IS NOTHING MORE THAN A COIL OF WIRE THAT HEATS WHEN CURRENT IS PASSED THROUGH IT.
IF IT WAS BAD, IT WOULDN'T DO ANYTHING AT ALL.
Mar 28, 2008 | KitchenAid KERC607 Electric Kitchen Range
Kitchen Ranges Logo
99 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
