Question about Liberty Hardware Home
How to find studs for bath room safety rails - Liberty Hardware Home
    Problem Solver:
  • 12 Answers
Just installed a few of those last week. A stud finder is your best bet. They've become very inexpensive and you will use it throughout the years so put it in your arsenal of tools. I recommend the Zircon brand (under $25). They offer several price ranges but the one I like and recommend has a deep scan mode and also shows you where both sides of the stud start as well as the center.
If you want an old fashion method, start by measuring from a corner and you should have a stud at approx. every 16". Tapping on the wallboard is not uncommon so you can hear the difference in the sound as you go from a hollow sound (no stud) to a more solid sound. When you think you've found the stud use a small nail to tap through the sheetrock, make sure your nail is at least 1 1/2" long, the sheetrock is 1/2" thick and you need something you can hold without hitting your finger while nailing. I have an old leather awl that I use and don't know if you can buy them anymore but if you find one grab it. If you've picked the right spot while tapping you'll hit the stud behind the wallboard using your nail. Move over about 1/2" at a time until you drive the nail into the wallboard and it doesn't hit a stud on either side and you'll have both sides of the stud located. The cover plate on you grab bar will cover the extra holes, if you didn't miss by much. If you have some exposed, because they're so small, they'll be easy to fill and touch up.
Another option is to use the new EZ anchors. They now have one that's rated at 30 lb. each and the grab bars should have three mounting holes on each end which gives you 90 lb. per side or a total gripping strength of 180 lbs. Unless the person you are installing for is over this weight you should be in good shape to use only the EZ anchors. My guess is that in the process of using the EZ anchors you're going to hit at least one stud and then you can use the longer screw provided by the manufacturer which will significantly increase you gripping strength.
Posted on Oct 22, 2010
CHANGE LIGHT BULB I BATH FAN
According to Broan's site - the model you specified has no light bulb - check specifications - you can search the site for the proper model and download the instructions.
http://www.broan.com/products/product/4108f1af-c993-4327-982f-1174f091fd6f
Apr 12, 2014 | Broan-NuTone Broan 110 CFM Premium Bath...
I had a wheel stud break off when trying to replace the brakes. I have the roters off and the old stud off. I had to saw the old stud off. No room to replace new stud. Can you suggest the best method in...
You were supposed to knock out the wheel studs, towards the back of the rotor and install the new stud through the back. You will have to knock out what's left of the one you sawed off in order to get the new one in.
Jun 28, 2011 | 2001 Honda Odyssey
No mounting instructions in package. will it work on an LG 47 inch led tv? To many peices in the package?
It should work with the LG 47". you need to find the correct bolts that fit the mounting holds on your TV. There should be a bag of bolts packaged with the Omnimount.
Feb 28, 2011 | OmniMount 40" 70" TV Wall Mount
Stud fing for safety rails
There is a device in which you can buy which is called a stud finder rather than tapping lightly with a hammer until you find a solid sound which is usually the stud......Hope this helps.
Oct 11, 2010 | Liberty Hardware Home
Hi.. we'll feel cold after taking bath from? 1. cold water 2 water at 40 c 4 water at room tempreature 3 water at 50c
"we'll feel cold after taking bath from?"
(Let's assume room temperature of the bathroom is 25 c.)
1. cold water
Assuming cold water means below room temperature, for example, 22 c. One taking a bath in water at this temperature would probably feel cold DURING his bath at least at first. However, a cold bath would tend to bring blood to the capillaries under your skin and create a warming sensation. But after you get of the bath tub, you would definitely feel cold unless the room were heated!
3) water at 50c
Most folks would feel quite hot while in the water at this temperature. And after exiting the tub, since the layer of water on his skin would probably still be well above body temperature (37 c), a chill would not set in until the water on his skin cooled down to below body temperature. So if he quickly dried off, he would avoid feeling cold.
2 water at 40 c
While almost completely immersed in the bath water, one would certainly feel warm unless there were a draft in the room, because 40 c is 3 degrees above normal body temperature. For the same reason as stated above (#3), he could escape feeling cold outside the tub if he dried off quickly.
4) water at room temperature
- If I had to select only answer, I would choose this condition that would make one feel cold after stepping out of the bath tub, because:
Upon exiting the tub of water at room temperature, one would certainly feel cold if there were a draft in the room. Even if there were no draft, one would still feel cold, because the water on his skin would be cooler than his body heat (37 c), and cause a finite evaporation of the thin layer of water on his skin, which is a cooling process. The skin's heat would be lost, because its energy would be used to evaporate the water.
Mar 30, 2010 | Scientific Explorer My First Chemistry Kit
How to change stud in rear wheel hub assembly. i need to know how to change the stud in the rear wheel hub assembly, and how do i go about taking it apart
Remove tire and wheel, remove caliper and brake rotor. DO NOT apply the brakes while the caliper is loose. Hit stud you want to replace hard with a LARGE HEAVY hammer to drive it out towards vehicle. DO NOT use a light hammer. It will distort the stud and possibly mushroom the end making it very difficult to remove. Once the stud is loose, you may or may not have enough room to get it out of the hole. You may need to pull the hub loose from the rear suspension to gain more room. Remove the stud. Place new stud in hole. Put a stack of washers over the stud, grease the threads, and using a new FLAT nut with the same threads as the lug nut, tighten until the stud is pulled all the way into the hub. Remove the flat nut, reattach the hub assembly (if you needed to take it loose) and reinstall the brakes.
Sep 28, 2009 | 1994 Ford Probe
1 handle pull and turn bath room faucet no hot
a common fault if the handle is forced the spindles get worn best to replace
Sep 12, 2009 | Price Pfister Home
I dont have the instructions to turn my simplicity 4 in 1 crib to a toddler bed
Install Safety Rails
Mattress support must be in lowest postition
Remove the Front Panel Contoured Top rail and Front Panel
Loosen connector pieces on the end of the leg of the Safety Rail to the End Leg using two of the Allen Bolts (11/2 in). Loosely attach the leg of the Safety Rail to the underside of the Mattress Support using one of the short Allen Bolts (3/4 in) through connectors. Tighten all three of the bolts holding the safety rail to the unit.
Repeat procedure with the other safety rail.
These are the instructions in the manual. Basically, you take off the front cross board and rail, attach the safety rails to each of the front legs. They kind of go 1/3 of the way across the front with about a 1 1/2 foot opening in the center.
Apr 08, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
Bath rail
This is now working o.k
Oct 30, 2008 | Home
Home Logo
64 people viewed this question
Top Liberty Hardware Home Experts
Donni Steen
Tom Chichester
Are you a Liberty Hardware Home Expert? Answer questions, earn points and help others
