Question about Sport & Outdoor - Others
We have a xuv 300cc 4 stroke,liquidcooled all-terrian vehicle Catgory G. It was always a little difficult to put into gear and now it won;t go into gear at all. Low, high or reverse. Please tell us what needs to be adjusted or done. Thank you
  • gordito5043 Oct 13, 2010
    The all terrian vehicle is an automatic
    Thank you we will try this
  • 10,865 Answers
Hello. Generally when an atv will not go into gear it is simply because it is idling too fast. Turn down the idle a wee bit at a time until it does go into gear. Joe
Posted on Oct 13, 2010
  • 11,896 Answers
Try adjusting the clutch and make sure there is fluid in the tranny.
http://www.mototips.com/how-articles/35005-how-adjust-your-clutch-pictures.html
Posted on Oct 11, 2010
2015 mercury 4 stroke 6hp won't shift out of forward gear
Remove the top cover and turn the flywheel back and forth and move the lever to Neutral. Sounds like a tight mesh of the gears holding the selector.
Apr 14, 2018 | Mercury Boating
Tailgate on envoy xuv won"t open and window is stuck in down position
Take your vehicle to a qualified repair shop ! You have not the knowledge or testing tools to even begin to diagnose this .
Nov 22, 2017 | Cars & Trucks
Gmc envoy 04, the gear shift slides up and down but the gear did not engage. another word, the xuv won't move
The shift cable probably has broken, usually the ring at the end breaks. Below is a diagram that shows the cable (it is item #7)
Aug 30, 2011 | 2004 GMC Envoy
About 4 yrs old 90? hp 4 stroke outboard runs
ignition timing may be off slightly.
Mar 12, 2010 | Boating
04 Envoy xuv 4 wh. drv. stays in 4 wh drv. HI
Try putting your transmission in neutral and slowly shifting the 4wd selector to each position but you have to wait a few seconds between selsctions as it has to go through your vehicles computer, shifting to fast will cause your symptoms. I hope this helped you out. Roger
Feb 08, 2010 | 2004 GMC Canyon
Does my 1983 suzuki 230 shaft four wheeler take transmission oil
yes it does take fluids, 10 weight 30 in rear end about half a liter and like 2 liters in the bottom end of the engne. to put the oil in the rear the screws on the top and take out bottom if u dont lubricate this, you will mess up your whole drive shaft and it will just slip
Sep 13, 2009 | Suzuki B-king Motorcycles
4 stroke Yamaha 50HP -Runs rough at all throttle levels
If it has the old points system you will need to set the points also adjust the carburatior screw the screws all the way in and back out 2 1/2 turns then get it to run turn the air mixture screws till it runs smooth. you want it slightly lean then enrichen it slightly, afterword shut the engine down and look at the plugs if they are gray black they are ok. good luck.
Jul 09, 2009 | RTO Oar Sockets
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
