Samsung model ln40a450c1d.TV is dead. all fuses good. Some power in power supply. Wont turn on.
  • clivegray01
    clivegray01 Aug 26, 2012
    hi therei have a samsung ln40a450c1d tv wont turn on is it my capacitors? if so which ones? please!!!
  • 755 Answers
Some power? I would recommend you should get a sams photofact reference on your set and find out what voltages you should have at all exit points from the power supply.
I did find this entry on some people who had similar problems.
If you are handy with a soldering iron and not afraid to take apart the set give this a try!
Because the Samsung LNS4051D would not turn on and the power LED would blink 4 times and the relay would click and this would repeat again and again. I replaced power supply board parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors, three had their tops bulged up slightly that I missed on initial visual inspection. After seeing the reports of problems with these caps on http://www.fixya.com/support/t1336881-will_not_turn_or_off , I replaced them with Radio Shack part 272-1032, 1000 uf, 35v. They are slightly bigger, but fit OK. TV is working fine now. Cost was 4 x $1.59 = $6.36 plus the time. I saved between $100 to 300 in the process of either replacing the board or getting the unit serviced. If you are not comfortable replacing components which means using a soldering iron, you can replace the power circuit board, available from http://www.discount-************/ProductDetails.asp?ProductCode=1030952-SAMSUNG&&Click=46
Posted on Oct 11, 2010
Testimonial: "Tried the 1000uf at 35volt Capacitor replacement and my TV came right on. They were slightly puffed up. Thanks very much.. Saved a lot of money...:) "
Samsung LN32A330J1DXZA will not power on. Problem occurred after moving TV from one house to another. Samsung Capacitor repair came out and pronounced it a dead main board and did not perform any...
reset the c.breaker or replace fuse in the main panel service from your home 2) test the power cord 3) test the switch 4) see if the fuse or c.breaker inside is tripper or replace fuse and try again.
God bless you
Nov 03, 2013 | Samsung BN41-00965A BN94-02070A...
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
Samsung ln40a450c1d no picture on screen when pressing the channel button it blink only with a low grey look no sound or picture thanks
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 05, 2012 | Samsung 460UX-2 LCD TV
SAMSUNG LN32C540F2D WONT TURN ON
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.3_27_2012_3_29_53_pm.jpg
Mar 27, 2012 | Samsung LN32C540F2D 32 LCD TV
Samsung lcd tv 40" model#ln40a450c1d.
try changing the aspect ratio to 16:9 if not it could be a burnout.
May 20, 2011 | Televison & Video
I have a samsung lcd ln40a330. When I try turning it on it does nothing. Is there a fuse to it.
Yes,the fuse in the power supply board,that the board,where the power a/c cord plug into it.Check ur power source?Yes,than the tv power supply board is dead.These modern circuit boards design never kill the fuse that easy.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 28, 2010 | Samsung LN40A530 40 in. LCD TV
My new samsung 400pxn wont turn on it just keeps on making a continues clicking noise every 2 to 3 seconds and the power lights flicks on and off
This tv still under warrenty?Call Samsung for service.Ur tv the power supply board is dead.That the board where the power a/c cord plug into it.That is ur tv power supply board and is dead.It must require replacing.Tries websites like Shopjimmy.com,ebay.com to buy a refurbish power supply board for the replacemnt,if the tv is out of warrenty.
Jun 17, 2010 | Samsung SyncMaster 400PXN LCD TV
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
1,141 people viewed this question
Top Televison & Video Experts
