SOURCE: About transfering video from the tape into PC
You do need a firewire cable (which is normally provided with the camera) and a firewire port in your computer in order to get images off the tape which you have recorded onto. The card however can be accessed via USB. The card can store video as well as pictures although if it is the card that you bought the camera with it probably has very low memory.
If I were you I would take one of these two solutions
Hope this helps- Any more questions just ask
SOURCE: Canon ZR85 camcorder won't turn on
Steps for removing the tape from a totally dead ZR85:
1. Turn camera upside down.
2. Move "Open/Eject" button to full right position (toward lens).
3. Manually push tape door open.
4. On the metal surface that sits between you and the tape, there is a very small screw. There is probably a yellow sticker next to the screw that says "Do not press on this part". With a small jewelry phillips screwdriver, remove that screw.
5. Push the metal plate (with tape) in the direction ofr the door and lift slightly. The metal assembly holding the tape comes loose, exposing the top of the tape.
6. Pull the tape upwards (out of the camera). At this point, the tape will still be engaged in the play heads. With the cartridge out far enough to see the heads, reach in with your jewelry screw driver and carefully lift the tape over the heads, and free from the camera.
7. Use the eraser on the end of a pencil to wind your tape back into the cartridge.
8. When re-assembling the mechanism in the camera, there are two curved slots on both sides of the piece you took loose. You'll need to thread these onto two posts inside before you place the top back in position and put the screw back in.
SOURCE: Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
SOURCE: i need driver for canon mv920 digital camcorder pal
Here is download page, click and follow instructions.
Run the driver on the computer before connecting camcorder, after the download has finished.
