Question about Broderbund PrintShop Pro Publisher Deluxe 20 for PC
How do I change the resolution in a photo to 2400X3000 to have a picture enlarge and printed. DPI would be 300
  • biffalo Oct 12, 2010
    I need to change the reolution in a Photo to 2400X3000psi. When I open it in Photoshop Elements
    a box comes up and says it is in the wrong format. What do you suggest
    Thank you 'Dragon, not only answered my question but gave me a coulple of new toys.
    sincerely Bill Hunter
  • 12,061 Answers
Ok, well there are quite a few picture resizers out on the 'net. These allow you to Resize the image adjust picture "Depth" and save as differing Formats too.
One such program is Picture Resizer, by Microsoft, installing this gives you a Menu, under the Right Click, menu, that allows you to select and adjust the pictures.
Go below and download the Power Toy... Install as Administrator, and if required set to Compatibility Mode for XP SP2.
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
master Google link, for Picture resizer freeware below.
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=picture+resizer+freeware
Posted on Oct 12, 2010
  • 857 Answers
Follow these steps :
•1
Open the digital image in a graphic editing program. In this example, Photoshop is being used. To open an image in Photoshop, click on "File" and then "Open." A window will appear, which will allow you to view the files on your computer. After you locate the file to edit, click on its thumbnail to open.
•2
Locate the commands to edit the image. In Photoshop, click on "Image" to view these options.
•3
Click on "Image size" in the menu that opens, if using "Photoshop." If using another graphic editing program, it may be a similarly worded option.
•4
Change the resolution by typing in the appropriate number. In Photoshop, you are given the option of using pixels per inch or centimeter. Click "OK" when you are finished making your change.
•5
Save the new image using the "Save as" command. You can rename the file instead of using the "Save" command if you wish to create a new file. Saving with the original file name or using the "Save" option will copy over the original file. The command to save a file is typically located under "File".
Posted on Oct 11, 2010
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
300 dpi image change
Yes you can. But 300 dpi is nothing. You could compare this to a question like, fits a yard in a football field.
When talking about 300 dpi, you also must know how big a picture has to be.
According to the manual, your camera can shoot pictures with 4288 by 3216 pixels. When you want to print 300 dpi that is 14 inch by 12 inch pictures. If you want to shoot pictures for smaller results like 6 inch by 4 inch or 7 inch by 5, you can chose a smaller resolution.
Don't be confused by the technical terms of 300 dpi. This is only used in the printing industry. I already printed till 4 times the resolution that was theoretical possible, and still the pictures look very good.
If you have a great picture, shot in the highest resolution, you should be able to make a print of more that 5 or 6 feet and still have a great picture
Nov 10, 2013 | Olympus Stylus 5010 Digital Camera
Canon SD1300 setting for 300dpi size 2.75 x 2.975 how to set camera
It's not a camera setting.
DPI is "dots per inch". This only has meaning when the picture is output (usually printed, but also displayed on a screen). You can make two different-sized prints from the same photo file, and they will have different DPI settings even though they come from the same file.
A photo editing/printing program will let you control the DPI when you print a photo (and some will let you change the value when you save the file).
Mar 29, 2012 | Canon PowerShot Cameras
Mar 29, 2012 | Cameras
My pictures are only 72 DPI. How can I change the resolution to higher quality?
The dots per inch setting (DPI) is meaningful only when printing the picture. As such, the camera simply fills in a default value of 72. You can change it in Photoshop or any other photo editing program. The resolution setting on the camera only changes the number of pixels in the picture, not how you print it.
Feb 16, 2012 | Casio Exilim EX-S12 Digital Camera
Can i change the compression and ratio on my canon powershot a570 is to shoot in 300 dpi?
Not really, since "300 dpi" is a print resolution specification. The camera takes pictures at whatever resolution you have set (0.3MP to 7.1MP on the A570).
If you print a 0.3MP photo at 300dpi, you'll get a picture 1.6 inches by 2.1 inches (smaller than a business card). If you print a 7.1MP photo at 300dpi, you'll get a picture about 8 inches by 10 inches. You can also get an 8x10 from the 0.3MP if you print at 60dpi, but the result will be rather grainy.
Again, "300 dpi" has no meaning to the camera.
Mar 03, 2010 | Canon PowerShot A570 IS Digital Camera
How do I increase the resolution from 72 dpi to 300 dpi on this camera?
You can use a photo editing software on your computer to change the dpi,
dpi has todo with printing and scaning dpi has no real change in the quality of your camera pictures
look at this page
http://www.rideau-info.com/photos/mythdpi.html
Nov 20, 2008 | Fuji Cameras
Labels enlarged
if they are diferent resolutions, ex. you change from 200 dpi to 300 dpi, you need to change something inside the printer like the gears (just reversing the platten roller gear and the the withe gera on the motor) and you are printing on 300 dpi with very small fontes.
Mar 11, 2008 | Zebra Z4Mplus Label Printer
Broderbund PrintShop Pro Publisher Deluxe 20 for PC Logo
67 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
