Question about Kenmore Dryers
Hello, Kenmore 70 series model 11096573220. Dryer will start up but then starts to make a whining noise then stops. It will start back up after letting it sit for awhile. I removed the cabinet, drum, & cleaned off the motor. I did notice the rear seal/felt was almost gone at the rear of drum. The rollers spin freely & I can turn the motor easily by hand. The drum rocks up & down a bit but don't know if that's normal. Any help & advice is much appreciated.
  • 50 Answers
SOURCE: makes squeaking noise after running for about 10 minutes
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Posted on Jan 30, 2009
  • 58 Answers
SOURCE: Motor draws current, won't turn drum.
The motor has failed & needs to be replaced
Posted on May 05, 2009
buffalonyman
  • 1865 Answers
SOURCE: motor runs but drum doesnt spin
The belt may have broken, you must open the dryer case and check the belt. If broken, you'll see it laying on the bottom
Posted on May 18, 2009
SOURCE: Dryer won't start
The problem is likely a malfunctioning centrifugal start switch in the motor.
More info, let me know.
Charlie
Posted on Aug 20, 2009
  • 82 Answers
SOURCE: Hotpoint VTD00 Tumble dryer. Motor runs ok without
The motor is bad and needs replaced. It could be the contacts or the bearings, either way you have to replace the motor.
Posted on Dec 13, 2009
Kenmore dryer 70 series
Check the vent for clogs and kinks. Could be something in the blower wheel causing the noise and blocking the vent.
Remove the vent from the back of the dryer, unplug the dryer, and reach inside the dryer vent to check for items lodged in the blower housing.
Feb 04, 2014 | Dryers
I have a Kenmore 90 series gas dryer Model# 7691269076912 When I push the start button it whines then nothin. I used wait a few minutes and just start running. now you push the start button, it whines then...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 20, 2010 | Kenmore 77632 Gas Dryer
Kenmore 70 series dryer makes buzzing noise and stopped working
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Kenmore 65942 Electric Dryer
I have a Kenmore Series 70 dryer wont start, just hums
Check for correct voltage at the terminal block on the back of the dryer, where the power cord attaches to the dryer.You should be getting 220/240 volts, check by way of a voltage tester.
If the voltage is correct, then could be the motor capacitor or the motor itself, or start button?
Good Luck !
Feb 07, 2010 | Kenmore 63942 Dryer
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Kenmore heavy duty series model 82672810 hearing a
i would guess you have something stuck in the pump.
you will need to remove the cabinet and then find the hoses going into the pump. when you remove the hoses, you will find something inside the pump causing the noise.
Feb 23, 2009 | Washing Machines
Makes squeaking noise after running for about 10 minutes
Nov 16, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
62 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
