Sony bravia- kdl-32d3000. Has started turning itself off and on by itself for about 10- 15 seconds.
  • 4234 Answers
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
Posted on Jan 05, 2009
waynejamescm
  • 67 Answers
SOURCE: tv bravia kdl 40v3000 problem turning on
Unfortunately, this is a failure of the balancer board for the backlight. The unfortunate part is that the balancer is not available by itself anymore, and the whole panel must be replaced, as Sony only has the balancers attached to new panels. You can contact Sony directly to ask for assistance, and it usually helps.
Hope this helps you...
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
  • 6 Answers
SOURCE: Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Posted on Dec 26, 2009
  • 50 Answers
SOURCE: slow moving image sony bravia KDL32M3000
Hello darwin_gabou, My names Dave! You have a bad A/V input board.
Part #: A-1376-788-A
Link to part: http://www.shopjimmy.com/catalog/product/view/id/169673/s/sony-a-1376-788-a-bm-board-for-kdl-32m3000/
Please feel free to contact me if you have any question. I'll be more then happy to answer any questions you may have!
Dave
503-432-9904
Premium TV Tech
www.pleasefixitdave.com
pleasefixitdave@yahoo.com
Posted on Apr 01, 2010
How to do a complete factory reset of a Sony Bravia KDL-32s5600 ?
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
Jul 07, 2014 | Sony KDL-32S3000 32 in. LCD Television
Sony Bravia KDL-46S4100, No Picture No sound
I have a sony bravia kdl 40v 5100 for less than two years and i did not purchased an extended warranty and now my tv is down.
I have no picture, no sound just a black screen when i turn the power on, the power (green) light is lite up and the tv turns off by itself for like less than 30 seconds. I have tried to press as many buttons on the remote control and on the side of the TV to get any message but nothing seem to happen. Any suggestions and solutions? Thanks
Aug 23, 2011 | Sony KDL-46S4100 46 in. LCD TV
Television randomly switches off and then back on again after a few seconds. Used to be very intermittent, no pattern to it. Has started doing this more frequently and now also when a games consol is...
You have a cracked solder joint on your TV circuit board. Only if you are competent to do so, the circuit pcb needs inspection and the offending joint resoldering. This is usually around the power supply area and the Line output transformer. If not competent to carry out the inspection, get a qualified TV engineer to look at it. Hope this helps :)
Feb 16, 2010 | Sony Televison & Video
My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
Oct 09, 2009 | Sony Bravia KDL-26S3000 Television
KDL-40XBR3 turns itself off; STANDBY light flashes 9 times
sony 52 inch tv in stand by mode comes on and off on its own
Jun 01, 2009 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
Sony Bravia has sound but no picture
hi have you check the sleep timer on the tv cause it might be on and you need to turn it off
Jan 12, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony Bravia turns off by itself
Replace the BU Mount pcb. Sometimes they are called the FB pcb.
Jan 08, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
