Question about Frigidaire Electric Dryer
Pushing the starter button and it buzzes. will not start.
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 17, 2010
WON'T START,BUZZ SOUND WHEN I PUSH THE START BUTTON
Sounds like a bad battery or a bad starter relay. Take the battery out and take it to an automotive parts house. Ask them to load test the battery for you.
If the battery test good, reinstall it in the bike making sure your connections are good. Press the start switch and listen for the buzz. Look for the starter relay. It's a one inch plastic cube. When you find it, press the start button while holding the relay. Is this what is making the noise?
If all you feel out of the starter relay is a simply click, and the buzzing is coming from the starter, you're solenoid may need new contacts installed in it or your solenoid might be bad.
Good Luck
Steve
Aug 22, 2010 | 2004 Harley Davidson FXD - FXDI Dyna Super...
Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Oct 21, 2009 | Whirlpool LER4634J Electric Dryer
When I push the electric start button on my 2004
use a test light to find out if there is power going to the starter. take the rubber cover off the top of the selonoid. it should be some where near the battery. one post of the selonoid should have power constantly and the other one should not untill the start button is depressed. if the light lights when you hit the button, there is either a problem with the power cable going to the starter or the starter its self.
Oct 14, 2009 | 2004 Yamaha WR 450 F
I have a 1999 Yamaha Wolverine. When start button
it sounds to me like you have a faulty terminal, check voltage reading to the relay from battery pos terminal, now push and hold button and recheck on same terminal, if it stays at around 12volts check terminal on other side of relay it this is lower significantly than first side replace again with new relay. of both terminals voltage drops you have faulty battery.
Apr 26, 2009 | Yamaha WR 450 F Motorcycles
Maytag MDG9316AWW Wont start
HI again. this seems to be a wiring harness issue. there may be a lose wire connection or some corrosion on the couplers that are connected to the timer and push button starter. I recommend checking all wires and clips for lose and corroded ends. make sure the clips aren't touching any other individual wire clips. The second issue may be the timer itself. it may have some damage with in the circuitry.
This reoccurring issue leads me to believe that there is something abnormal within the current flow. this. This abnormality is continuing to blow the starter switch. there are only three areas you can check to find this issue. the timer itself should be check for proper voltage and the wires and harness should be inspected as well. The last check would be the terminal block. Check the terminal block for lose power cord wire connectors.
If you have anymore question, please feel free to ask:)
Apr 08, 2009 | Maytag Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Starting problems
I'm having starting problems with my MOTO 6.5 ther is a 'buzzing' noise when the start button is pressed(the bike will not start or even try to fire) is it the solenoid? The buzzing noise is coming from the small item near the battery is this the solenoid? The battery is almost new so i know this isn't the problem. can anyone help? Sounds like a problem with the starter motor. Are you sure that the motor/piston is actually moved by the starter motor? If notthe buzzing noise is from the starter motor itself that runs 'free' without engaging the magnet that connects with the motor. The magnets can get 'sticky' and sometimes helped with a Careful hammering onto the starter motor. In any event you will need to rebuild or replace the starter motor unit. This all assumes that the moto still starts whenyou push her in second gear, right? Hope this helps and good luck. ,,,
Nov 10, 2008 | 2000 Aprilia Moto 6,5
Frigidaire  Electric Dryer Logo
49 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
