Older ge washer pump
I am trying to replace a pump on an older style ge washing machine and i have only replaced a pump on a beltless style .. I am not sure how to proceed .. I have the hoses off but do not want to mess anything up. any tips?
  • Plumber gal May 31, 2008
    Thank you the operation was a success!!
  • 770 Answers
Loosen the clamp around the rubber coupling 1/4 " nut driver do not take it off completely just enough to get it off the top of the pump then remove the 3 mounting bolts on the bottom of the pump and install new
Posted on May 31, 2008
  • Gary Davd
    Gary Davd Jun 01, 2008
    Glad to help plz change the rating to fix ya Thanks
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
GHW9150P Duet washer will not finish cycle
Just click below for code error;
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope it may help you;
Regards,
VOTIT
Sep 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE Washer top-load WLDSR416FOWC
redarrow.gif Top Load Maytag Style
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
It's slow to fill
It's overfilling
It's underfilling
Jul 23, 2008 | GE WDSR2080D Top Load Washer
Washing machine comes up with code fault 51. Could you please explain?
Hi just read your posting.The error code you have indicated is called RECIRCULATION FAULT.This means that when your machine is on the recirculation mode it is losing water.Please look under the machine for me to confirm which pump style you have in your model of machine.If you see a black fan to the front right you have the older style.Please reply and let me know if you have the older pump or newer pump.If you have the new style of pump then you will not have the black fan.This information will help me guide you in rectifying this fault.Looking forward to your reply.
Sep 20, 2010 | Fisher Paykel Eco IWL16
My ge adora washing machine is not spinning how do I reset to get it to spin?
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.
Jan 03, 2010 | GE WSXH208A Front Load Washer
Water won't dump
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Jul 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
Water leaks under washer on floor - olderGE profile
I see Eric C was correct, that you did not post your correct model number. You did say older GE, and from your description it sounds like you need to replace the WH23X42 water pump (about $50). It is one 1/4 inch clamp on the bottom holding on the flexible drive, three 5/16 hex head screws mounting the pump body to machine, and four squeeze style spring clamps holding the hoses. (be ready to catch the water when you remove hoses)
Feb 17, 2009 | GE Profile WPRE6100G Top Load Washer
GE commercial washer wont spin or drain
If your washing machine is 20+ appliance years old, it's probably due for replacement.
Jul 15, 2017 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
Help! My Kenmore washing machine goes through all of the cycles until it comes to draining. I can hear it humming like it is trying to drain but nothing happens. It is an older top loading model.
Well if you have a belt drive model then your wigwag solenoid is probably bad. This shifts the tranny into the spin and open the drain flap on the pump. If you have a newer beltless model then i would say your drive coupling is probably shot. Post the model number in the comment box for a more precise answer mon ami.
Jan 16, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
