Question about Boating
Need a schematic of motorguide varimax 55lb thrust transom mount motor
3 Suggested Answers
SOURCE: Trolling motor will not spin with out being turned by hand.
This may sound really dumb but it's worth a shot. I bought a trolling motor and it did the same thing as yours. I put up with it until I broke a prop blade. When I was changing the prop I discovered about fifty feet of monofilament fishing line wrapped around the shaft, partially melted, hidden by the prop hub. Once removed, it worked fine. Hey, try it, can't hurt.
Posted on Dec 11, 2008
  • 10 Answers
SOURCE: bow mount 80lb to transom mount
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 08, 2009
I have a transom mount 12volt i was fishing the other day and it just quit working come home and checked my voltge that was but doing some testing i found that all the wires going to the actual go to the...
The motor windings are very low resistance so checking for a short is difficult. However, It sounds like a open rather than a short circuit. The switch might be open. Try jumping the switch to see if that works. If not then visually inspect for opens. To go further would require a schematic, disconnecting wires, etc. It would help to have the nameplate information or a copy of the schematic to really help, Send me an email at vze2m6dn@verizon.net. Ed
Mar 16, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
I have two 36 volt 107 lb thrust Great White motors mounted on the port and starboard sides of the polling tower of my flats skiff. My fishing application has changed and I wish to mount one of the motors...
Yes it should do, this is the bracket
Motorguide MGA515A2 Great White Troll Motor Removable Mount 17031 eBay
schematic of parts
http://www.boats.net/parts/search/Merc/Motorguide/2006/950010220/Gator%20360%20Flex%20Mount%20(Black)(MST9360FW)/parts.html
this is the installation instructions for the Gator 360
http://www.motorguide.com/userfiles/file/Support/InstructionSheets/Gator-360-Flex-Mount-Instruction-Sheet.pdf
Jul 23, 2017 | MotorGuide Boating
I HAVE A MOTORGUIDE MOTOR WITH THE FOLLOWING LABEL ON IT... "EP2.3HP" WITH SERIAL #SN 42663". LABEL ON TOP OF MOTOR IS "36 VOLT DIGITAL. VARIABLE SPEED". CANT FIND ANY INFO ON THIS MOTOR ANYWHERE? IT HAS...
I need the information off the tag motor frame volts amps and shaft type and I can tell you how to make it work. you didn't leave your e-mail address, also please rate. Thank you.
Aug 08, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MY MINN KOTA 30LB THRUST MOTOR HAS DEVELOPED A NOISE IN THE LOWER UNIT LIKE A LOOSE BEARING.IT SEEMS TO BE WORSE IN REVERSE
Hi!
Here is a schematic for your motor:
Endura 30
It sounds like the motor has leaked water into it and wil need to be cleaned up, have the brushes, seal kit and bearings replaced.
Best of luck!
Mike
Jul 09, 2009 | Minn Kota Endura 30 Freshwater Transom...
New MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
May 23, 2009 | MotorGuide Electrical Supplies
Bow mount 80lb to transom mount
May 06, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Boating Logo
139 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
