I have a Dyna-glo RMC-95-C2 kerosene heater made by CFM RMC International. I changed the wick and it now it sends out a lot of smoke.
5 Suggested Answers
SOURCE: can not replace wick in dyna glo serial number RMC-95-C2
I believe dyna-glow RMC95 series of heaters are equivalent to DH2300 series heaters. Go here to get to the manual.
http://www.yourheater.com/DH2301-3%20owners%20manual.pdf
Posted on Jan 26, 2008
  • 3 Answers
SOURCE: Help
Dyna Glo 95 c4 Manual
http://www.owneriq.com/mdownloads/8979e0af-dfee-45f1-a8ba-c05c2f5ed4a8.pdf
Posted on Dec 07, 2009
wilsodfarm
  • 986 Answers
SOURCE: i have a dyna-glo rmc-95-c2 kerosene heater, i
when you replace the wick did you set the control all the way down
Posted on Feb 11, 2010
  • 4736 Answers
SOURCE: need to see pictorial instruction
I think the Dyna-glow RMC95 series of heaters are equivalent to DH2300 series heaters.
In any event, the wick you purchased should have ahd the installation instructions included with the wick.
If it didn't or you tossed it, Here's a link to the DH-2300 series heater's Owners Manual, which may help you.
Good luck. Be sure to wear rubber gloves when you try to install the wick. Particularly, if you still have kerosene in the tank.
Posted on Feb 11, 2011
Need to see pictorial instruction on how to replace wick in a Dyna Glo RMC-95-C2 kerosene heater
Feb 11, 2011 | Dyna-Glo RMC-8001SS Heater
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
Jan 31, 2011 | Dyna-Glo RMC-8001SS Heater
Dyno-Glo RMC-95-C7 kerosene heater. replaced wick
once the tank gets low(on E) put the heater outside and let the remaining fuel burn completely out. This will burn off the residue build up on the wick and make it easier to turn off manually. do this often. i also use an old toothbrush to "fluff up" the wick. if the residue is too hard for the toothbrush bristles, flip the toothbrush over and break up the residue with the back side of the toothbrush. once all (or nearly all) of the residue has burned off you may see some smoke when you ignite the wick again. also, it may smell for a bit. I always light and shut off the heater outdoors. I mounted a dolly (table withe 4 wheels) under the heater to make transporting it easier. hope this helps!
Jan 02, 2010 | Dyna-Glo Heating & Cooling
Have a Dyna Glo RMC-95-C2 and I can't get it to lite.
You have to change the batteries.. the manufacturer shipped it with **** batteries.
also take it apart.. very simple and clean out any soot..
Soot will cause heavy smoking...
The wick should last more than a year ....
Dec 14, 2009 | Dyna-Glo RMC-8001SS Heater
Kerosene heater
Jan 31, 2009 | Dyna-Glo RMC-8001SS Heater
Help
Aug 31, 2008 | Dyna-Glo RMC-8001SS Heater
Can not replace wick in dyna glo serial number RMC-95-C2
As "guest" reported, the wick replacement for RMC95 series is the same as his posting for the DH2301.
After calling my local Tractor Supply and searching the net, I had it but it ain't easy. My sleeve doesn't come out necessitating cranking the knob up (wick will be level with the top) find the three holes (more like two are slot and one is a hole) then where the diagonal grooves are, there is ANOTHER HOLE which you must snap the pin in both of those all at once!
The good news is, you get one in, the rest are cake. I was pretty frustrated so I hope this helps others.
Dec 08, 2007 | Dyna-Glo RMC-8001SS Heater
Heating & Cooling Logo
160 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
