Question about HP Compaq nx9020 Notebook
Opening laptop Hi there, I have a compaqnx9020 laptop. I am trying to open the laptop up but when i remove all the screws that are visible, the unit still remains sealed, which leads me to believe that there must be screws underneath some of the keys on the keyboard. Are you aware of such a problem and if so, which keys are the screws located under?? Many thanks for your help
    Problem Solver:
  • 18 Answers
Remove the two screws on the back of the hinge covers. then pry off the speaker panel/buttons in front of the screen. there are three screws that hold the keyboard in place. remove those and then remove the keyboard. there are two screws under the keyboard in the center of the unit. Remove those. There are also 3 screws that can only be removed if you pop out the hard drive. Hope this helps. I have had mine apart many times
Posted on Dec 28, 2008
    Problem Solver:
  • 31 Answers
Remove the cd rom and the battery you will see the screw.
Posted on Jun 04, 2008
How do i open a tdk tp6701blk
I don't know your particular unit, but I see screws hidden under the feet on many small electronic devices.
Apr 20, 2013 | TDK Sound Cube - Black TP6701BLK
Bios password
Hi!
Bios password, time, date and other user settings are keeped in a CMOS powered by a 3V battery.
Removing this battery for a couple of minutes resets the BIOS password and also the time and date.
It's very easy to do so in a Desktop PC, because the battery is visible on the motherboard after opening the case, and it can be removed simply by using a non-metal tool, even a toothpick.
But it is complicated at laptops, because accessing the motherboard means taking the whole thing appart, and that requires some tools and skills.
In both situations (desktop and laptop) the power cord must be disconected before opening the case, and of course the laptop battery should be also removed.
My advise is if you are not experienced with opening the case of a laptop, to ask a qualified person to do that.
Bogdan
Aug 29, 2011 | Computers & Internet
Hello, I have an e-system 4213 laptop with a wobbly power connection. It probably just needs a bit of solder. I've removed the battery, disc, and every visible screw, but I can't get the machine to...
The top half and bottom half of the case may be clipped together besides being held together with screws.
There may be additional screws in the battery compartment or the DVD/CD drive slot.
Try separating both halves by pulling it apart near the battery opening or the DVD/CD drive slot.
Apr 22, 2011 | ASUS Computers & Internet
Can't get the back cover off a MPC transport 2300 laptop, removed all visible screws
The remain screw is under the Keyboard, to open it, you need to open the lid around the keyboard unit, it use only a small clip, with small screw driver you can lift up the lid.
To do this, please be careful, it's a small things..
Feb 26, 2010 | MPC Computers TransPort T2300 Notebook
I have an old GE/Hotpoint dryer ddg6380 bal model. about 1984. I am trying to locate the thermostat and have been told it is below the lint trap. Cant find them, could they be visible on the plate, but...
Unplug the unit. Remove the lint filter...and look down into the opening where the filter was. You should see a folded sheet metal box about 4 inches square and down about 4 inches inside the filter opening. This box is removed by removing the Phillips screws inside the dryer on the interior front wall. You can feel for them with your hand or with a light inside...stick your head into the dryer opening and look down and back toward your feet.
Removing the screws reveals the 2 operating thermostats. As you remove the screws hold the box so it doesn't fall into the blower area below the filter.
When you are re-assembling be sure none of the thermostat wires touch the cover after it's assembled.
Good luck.
Sep 16, 2009 | Hotpoint Dryers
Trying to open it up?!?
In addition to the screws visible outside the case, you need to get at screw(s) underneath the keyboard. By removing the hinge cover/speaker faceplate, you can remove the screws holding the keyboard in, and lift the keyboard out to get at the last screw(s).
Apr 08, 2009 | HP Pavilion ze4125 Notebook
Trouble seperating top cover from base/mobo / asus f3s notebook
Have you removed the keyboard, sometimes there is a screw under the keyboard that holds the top and bottom of the case together.
Most laptops have clips/indents that clips top and bottom half of the case together. Start on one side, preferrably at an opening where the CD/DVD drive is located and gently apply pressure to separate the case along that edge. Once you free a catch/clip start working along that edge and continuing around to each side of the case.
Mar 26, 2009 | ASUS F3SC-B1 Notebook
Where is the cpu located in the Lenovo Ideapad Y510
hi,
I Lenovo Notebooks cpu is located at the extreme left upper corner and when you will open then the heatsink will be visible on it.
after opening the screw of the heatsink simply turn the non removable screw and then lift the cpu.
Dec 26, 2008 | Lenovo IdeaPad Y510 Notebook
Opening a Gateway Solo 2150 laptop
I found the answer on another wed site. I tried it on my Gateway Solo 1500 and it works! The extra screws are hidden on top. You carefully remove the small face plate around the power button. I used a very small screw drive to lift it off.
Opening Gateway Solo 1400
by Aelanna - 2/3/05 11:04 AM In reply to: Gateway SOLO 1400 by hunjibunji
I'm also an A+ certified tech, but I've done notebook service for a lot of years. I just finished opening up a Gateway Solo 1400 and it was NOT easy! There are no screws holding the keyboard on the bottom of the machine. You can get the case open about 95% and there will be one area stuck, in the back near where the screen cable goes into the unit. There is a hidden screw on the top of the case next to the hinge. To get to it, you have to remove the two screws that hold the plastic hinge cover and pry off the cover. I only managed to find it after removing the keyboard, the display, and the panel with the LEDs and power button. (The screws holding the keyboard are on the top of the machine, underneath the cover with the power button on it.)
May 02, 2008 | Computers & Internet
Memory
You've to see at the back of your notebook, you have to unscrew that say say KB. Incase it is not written then unscrew all the top and middle screw.Some model after unscrew you have to remove the front panel first before removing keyboard or some model remove the front panel and KB screw is underneath it.By saying Front panel, I mean the panel at top where you press power-on button and all.
Apr 18, 2008 | Compaq Armada E500 Notebook
HP Compaq nx9020 Notebook Logo
142 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
