Question about Canon DR-7580
Canon dr 7580 erroe 32 - Canon DR-7580
  • 490 Answers
If the main board (CPU PCB) not installed properly you get this error.
S. Mohan
Posted on Oct 17, 2010
My Canon DR 7580 has image void in the front image. Looks like two void columns. The Image reader is clean. Can the upper and lower imager be swapped to see if the problem is the upper imager?
You cannot swap upper and lower images. You can scan the page twice (in duplex mode) by reversing the same. Ensure which side is giving perfect output.
DR 7580 is a CONTACT scanner and hence the paper has to touch the glass surface properly. There are two full sized rollers, just above/below the scanning module, which does this job. Ensure that they are proper and there is enough pressure, press and release 3-4 times to check it is stuck.
S. Mohan, Chennai, India
May 19, 2011 | Canon DR-7580
Canon dr 7580 error code E30
E30 is a Error related to Exhaust Fan. Pls check if the Fan is working, replace if required. If the scanner was used in a dusty environment, the dust can clog the free movement of the blades. It may require cleaning.
Nov 18, 2010 | Canon DR-7580
Canon dr-7580 error 32
According to the service manual if 6080 and 9080c cpu/motherboard are interchanged this appears.
Oct 05, 2010 | Canon DR-7580
I have a canon dr-7580 with a P00 error. I've blown it out but no paper found. what next
Use Qumatool to check if all the sensors are working okay. Normally sensors dont fail, there must be a small piece of paper (like the 'dot' of pre-printed stationery) sticking somewhere.
S. Mohan
Aug 31, 2010 | Canon DR-7580
Canon dr-7580 scanner how to initialize cis
If the Black lines are jaggered and are vary in size with different levels of brightness, then most likely it is scratch on the glass. If the lines are sharp and perfect and does not change when different brightness is chosen, then it could be failure of CIS module (Try this under B&W mode). To the best of my knowledge there is no concept of initialising the CIS, you may need to clean the Shading sheet.
Apr 10, 2010 | Canon DR-7580
Canon DR-7580 misfeeds intermittantly cutting off about one to two inches of the top section of the page.
Select 'auto detection of page size instead of a fixed size.
S. Mohan, India
Mar 01, 2010 | Canon DR-7580
Canon Dr-7580 not scanning two sided.
Check if you have chosen the 'duplex' option.
S. Mohan
Jan 11, 2010 | Canon DR-7580
Canon dr 7580 is not scanning multiple pages.
Check if you have selected 'multipage' option. Then you will get only a single file, but with multiple pages.
If your question is that the second or subsequent pages are not pulled in for scanning, then you need to change the rubber rollers.
S. Mohan
Sep 30, 2009 | Canon DR-7580
In need of a service / parts manual for Canon DR 7580 scanner
You can get spares from http://www.scannerparts.biz/servlet/StoreFront
Service Manauals are little difficult to get, need to search the web patiently. Be sure of the site, there are quite a false sites that rob you of your credit card details. S. Mohan
Jul 01, 2009 | Canon DR-7580
81 people viewed this question
old marine
old marine
