Question about Bosch Exxcel WFO 2265 Front Load Washer
Awful bearing noise on spin. - Bosch Exxcel WFO 2265 Front Load Washer
  • Bosch Master
  • 3,463 Answers
Remove drum belt and spin drum by hand, if it is noisy or feels rough, then the main drum bearings have failed, which is a major repair.
Posted on Oct 11, 2010
My machine makes the awful noise when running do I need to tighten the belt or replace it
Noises can be a few things, first remove the belt spin drum by hand it should be fairy smooth and Quiet, if not then chance is the rum bearings are faulty quite an expensive repair....
Jan 31, 2011 | Washing Machines
My washer is making an awful noise and it wont spin like it suppose to what is wrong
your inner drum bearing lip-seal has gone bad and the inner drum bearings are now water soaked and rusted and need replacement,parts are cheap,but depending how long it takes to remove and clean the bearing races and time/labor you will need to check on in your area
Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine does not stop filling up it runs over.It still spins the water out, but was making an awful grinding noise.
FIRST, IF IT DOESNT STOP FILLING YOU EITHER HAVE A CLOGGED VACUUM LINE OR A BAD PRESSURE SWITCH. AS FOR THE NOISE WHEN IT SPINS, TAKE OFF THE BELT, CHECK PULLEY FOR THE MOTOR AND PUMP, IT SHOULD SPIN FREELY AND TIGHT. IF THEY BOTH GOOD, AND THE NOISE IS AROUND THE MIDDLE OF THE TUB ON TOP OF THE TRANSMISSION, MEANS YOU HAVE A BAD TUB BEARING
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH THE PROCESS IF NEEDED.
Jan 14, 2010 | Admiral Washing Machines
Loud noise on spin cycle...sounds like a bad bearing maybe????? any advice on this noise?
It's hard to pinpoint it from your description. But it might be either the motor coupler, or transmission. Does it agitate alright with no noise? It could be center shaft bearings too if it only makes the noise in spin. Either way, with transmission, or center shaft bearings, the transmission needs to be removed. The motor coupler is a lot easier. It's what drives everything and is used instead of a belt. If the rubber is worn out, it can make an awful noise. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Whirlpool Washing Machines
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
I own a 06 chevrolet 4wd. it makes an awful roaring noise
There is a bearing, somehwere that is the most likely cause.
Does anything alter the sound, accelleration, decell, moderate turning (thinking to unload one side and load the other side of the vehicle)?
My vote would be for a bearing, and they are hard to tell until you tear the offending bearing apart...
Sep 21, 2009 | 2006 Chevrolet Silverado 1500HD
Spins during agitation makes noise
Welcome to FIxya
I would check the belt and i would also check the bearing
hard to help you out with out seeing it but i would check those first ....
hope this helps out have a good day :)
Oct 29, 2007 | Whirlpool LSB6200KQ Top Load Washer
Bosch Exxcel WFO 2265 Front Load Washer Logo
191 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
