Question about HP OfficeJet 6110 All-In-One InkJet Printer
A small piece of paper is stuck in the rollers. How do I get it out?
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Open the door back of your printer and remove it from there
by pulling it out
If i helped you pls vote me
Posted on Nov 01, 2010
How do I get the stuck paper out of a copy mashine?
You will need to take the machine appart. There are usually access pannels for all areas that paper go through for this exact reason.
Apr 13, 2012 | Office Equipment & Supplies
CannonMP495- paper jam when there isn't
Because there might be small dust/paper part would be stucked at the roller sensor just make sure and make it clean you can find some dust or small paper piece stucked with your roller so its showing paper jam error when theres no paper inside.
Aug 12, 2011 | Canon PIXMA MP495 InkJet Printer
Hp laserjet 1010 has a paper jam and the paper was torn and a small piece has stuck on the printer... what shall i do... healp me please asap
You need to remove the small piece of paper. Try turning the rollers to free the paper, it will be tight to turn the rollers.
May 30, 2011 | Computers & Internet
Printer keeps saying i got a jammed paper there is no jammed paper
There are many places in a printer where a small piece of paper can get stuck. It's not always a sheet of paper. Open all the access panels and check the roller track for pieces of paper. If it is clear, unplug the printer for a few seconds and the plug it back in. This should clear the problem if it was in error. Also check the paper feed for too many sheets stuck together jamming the feed. Before loading paper always "fan" the paper first to avoid sheets being stuck together.
Apr 14, 2011 | Canon Office Equipment & Supplies
Left corner is folded down on page
Sounds like an issue with the feed rollers. The roller on the left side might be hung up and is causing the corner to fold over when the paper is pulled through. I would try checking the feed rollers in either the actual tray or the back of the printer. Another thing to check is the other tray (the manual one). Does the paper fold? this should help you narrow down where the problem lies.
Mar 02, 2011 | HP LaserJet 4350 Printer
It says my printer has a paper jam but i dont see no paper jamed and i refill it and it says say thing like it would let it go like its going to print then says jamed paper
Try and see if you can locate a small piece of paper that might be causing your printer to jam. Turn the rollers and see if you can see any small pieces of paper stuck in between the rollers.
Mar 02, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Hi, how do fix a paper jam? 1st page printed ok, 2nd page jammed. I pulled it out backwards but the centre of the page was torn and a small piece missing. I can't see where I can clear that small piece of...
Unplug the power cord and open the cover and remove the TONER and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 11, 2010 | Brother HL 1240 Printer
Hp laserjet 2420 paper jam 13.20.00
Hi, check throughout the printer for small pieces of paper stuck, broken sensors etc, clean the rollers in the paper tray 2, check for wear. clean the registration rollers (under a metal flap under the print cartridge) do not clean the transfer roller (the spongey roller sitting under the drum!)
Feb 09, 2010 | HP LaserJet 2420 Printer
Error e04-14
Looking at the printer from the front with the top open (like one were changing ink cartridges), I forced (gently) a piece of card stock through the rollers and found there was a small piece of paper stuck in the right side feed rollers. This paper was not visible in any way. Just in case someone doesn't know this, Push the "Start" button to get the rollers turning.
When the next piece of regular paper went through it "bunched" or "crinkled" the leading edge in the same place. Two or three sheets later it all appears to be working normally again.
Hope this helps someone else.
Nev
Dec 29, 2009 | Panasonic DP-C264 Copier
On sidekick 1200, The right corner of many pages get bent or torn. It happens with an older one and a brand new one.
All scanners have sets of rollers for paper movement. Sometimes, a small piece of paer can be stuck to the roller. This piece of paer can affect paper movement resulting in paper getting torn. In this case probably a piece of paper is stuck in the right corner. This can also happen if a piece of cellophane sticker is on the roller.
S. Mohan, India
Jul 08, 2009 | Bell & Howell Sidekick 1200
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
