Question about Avaya Corded Phone avaparp18d
When I pick up the handset, the intercom picks up. How can I set it to automatically go to next available line to make a call?
This programming needs to be done from Ext 10 or 11
Press Feature 00
Press LEFT intercom TWICE
Press RIGHT intercom ONCE
press the 2 digit extension number you want to set up
PRESS ** ( STAR STAR)
then press the lines in the order you want them to be picked up.
When finished:
PRESS ** (STAR, STAR)
PRESS feature 00 to exit programming.
Done
Posted on Oct 11, 2010
Testimonial: "Thank you! I couldn't find this programming anywhere and you made it simple! "
Why do I need to push a line to dial out
Since the system can make both intercom calls and external calls it is factory programmed to consider a number dialled to be intercom hence need to pick a line before you can make an external call. However it is also possible to program your phone to automatically access an outside line on lifting your handset in the installation manual
Feb 27, 2014 | Panasonic KX-T7730 Corded Phone
My company has an Avaya phone system that uses Partner 18d phones. When you pick out the receiver the phone would go to one of our 4 outside lines, but recently on ext. 10 when you pick up the receiver it...
http://dstech1.com/changing-the-line-that-is-picked-up-when-you-lift-handset/
All releases of Partner
Lets say that you currently pick up line 1 to make an outgoing call, but you want to pick up your last line (in this case we will say we have 6 phone lines).
This feature is called "Auto line select"
To program Auto line select:
From extension 10 or 11:
Press feature 00
LEFT INTERCOM
LEFT INTERCOM
RIGHT INTERCOM
Enter the extension number of the extension you need changed.
press ** (start, star)
Then the order you want the lines to get picked up
Then ** (star, star) when done
When finished, press feature 00 to get out of programming.
So, in this example I would enter my extension number (22) and press ** (star, star) and press line 6, line 5, line 4, line 3, line 2, and line 1. Then I press ** (start, star) to signify that I am done programming Auto Line Select. And feature 00 to get out of programming.
Easy as pie.
Aug 20, 2011 | Avaya 700340193 Corded Phone
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
Hi: I have a Panasonic KX-T7420 phone. When one of the incoming lines is ringing and I pick up the handset, it picks up the intercom and not the incoming line. Is there a way to get the thing to answer...
There are 2 things that would prevent you from being able to answer a ringing phone by picking up the handset. Your phone has to be ringing, and you need to set preferred line ringing on incoming calls.
The second part is easy. Press PROGRAM 99 and dial 22 STORE on your phone. Now when a call rings on your phone you can pick it up. If you can't, then your phone is not ringing.
Ringing is set in system programming.
Carl
Aug 04, 2010 | Panasonic KX-T7420 Corded Phone
Default line
From your phone press PROGRAM dial 19 ENTER (or STORE) x ENTER (or STORE) then exit by pressing PROGRAM (or EXIT)
If x=0 it's no line If 1 (what you want) it's idle line if it's a 2-digit number 01-36 or the CO button, it's a line, and 3 or INTERCOM is the intercom.
Carl
Jul 03, 2009 | Panasonic KX-T7633 Corded Phone
I want to be able to just pick up the handset and have it
Depending on the software level, there is a possible chance for this to work...
first question though... can you dial a 9 to get a line out?
If this is possible, that means that we can change the PRIME LINE for a line pool access rather than intercom.
-> Get into system programming
-> get into TERMINALS&SETS and type in your extension
-> enter LINE ACCESS and hit next till you find PRIME LINE it should say I/C (this is intercom)
-> press change till you see PoolA
-> hit next and RLS to end programming.
Now everytime that you pick up your handset, it will pick the first available line out!
Feb 22, 2009 | NorStar Meridian M7310 Phone
Want to pick up phone and get an outside line
Yes, put your lines in a line pool, then have your phone automaticly go to Line Pool: <Whatever Pool # you picked, 1 thru 3>
Dec 17, 2008 | Nortel T7316E 2-Line Corded Phone
Misplaced one of the phone
I looked up that model and they are equipped with intercom service.
What good would an intercom function (I ask myself) without some way to ring another handset? It wouldn't make sense to have to holler for someone else to pick a handset ;-)
The phone's control layout is identical to ours (it is 2.4 gHz instead) so check the lower right-hand corner for a button perhaps marked Hold & below it 'Intercom' printed.
Using that function, you choose the station # and it will ring the remote (lost) handset until someone picks it up and presses Talk or speakerphone button. .
Sep 03, 2008 | Panasonic KX-TG1033S Cordless Phone
Receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
Avaya Corded Phone avaparp18d Logo
375 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Cabanaboyz
Cabanaboyz
Level 1 Expert
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
