Question about Maytag PYE2300AY Electric Dryer
Maytag gas dryer belt routing and mounting of tensioner on ModelMGD5700TQ0
  • longboard369 Jun 09, 2008
    Found same web site earlier and problem solved. Thanx for helping .
You are awesome. the link helped!!
Posted on Jan 30, 2009
Dryer not getting hot!
Posted on Sep 22, 2008
  • 525 Answers
I have found a link that should provide you with the belt routing diagram you are looking for.
Any trouble,post me back.
Dave E. (Illeagle)
http://www.repair-help.com/kb/index.php?article=105
Posted on Jun 02, 2008
Belt tension too loose
the typical tensioner should be able to be bent a little to tighten up the tension
Sep 27, 2012 | Maytag Parts Maytag 801429 Dryer MAYTAG 30...
Maytag neptune gas dryer belt routing diagram
ok, from page 6-3 of the service manual at "http://appliancejunk.com/forums/index.php?PHPSESSID=528fec4bdaa3f056d2c3cc804aa5dc8d&action=downloads;sa=view;down=67" :
check that you still have the spring and that it is still tight.
good luck!
Feb 14, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Maytag lde 212 dryer, drum not turning, new belt I think it is routed correctly but seems loose, can you tighten spring tension on the idler pulley?
hi easyrb...
If your belt is new and it is loose, then you have routed your belt wrong.
Follow this link and you will see the correct way to route your belt
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Jul 11, 2011 | Maytag Dryers
I need a diagram on how to route the belt on a maytag atlantis dryer model number mde7600yw and also a diagram of the tensioner spring for the tension pulley
Hi and welcome to FixYa, I am Kelly
The flat side of the belt goes against the drum and the routing diagram can be found here:
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramE
If you need more assistance after viewing the diagram and attempting to install your belt without success, just respond here and I can help you.
Thanks for choosing FixYa,
Kelly
Mar 16, 2011 | Dryers
Belt came off. not broken but when i went to replace its about 4 inches to big, (slack in belt) the tension spring is not tight is there a certian route i should go with the belt,
Yes there is. The flat side should go against the drum and the tension spring pulley. The ribbed side should go against the motor pulley. The tension arm is probably out of position. You'll have to try it in different positions. Look at this diagram. It don't show how it goes but it may help. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170715&diagram_id=1353177#d1353177
Oct 26, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Replace dryer belt
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Maytag PYE2300AY Electric Dryer
Belt too loose
Are you sure you have the belt routed correctly? You can verify by going to repairclinic.com and clicking on the "Repair Help" link at the top of the page. On the following page is a link entitled "Dryer Belt Diagrams" under the "Special Features" section. You will need to view diagram E for Maytag. NOTE: There is a tension spring on your idler. Make sure the tension spring has not come loose or fallen off. I hope this helps you. If you have questions, please let me know.
Jan 14, 2009 | Whirlpool LGR7646E Dryer
How to instal new belt.
Remove the back panel, there you will find a tensioner, that will release the pulley.
Undo the belt routing and install the new one.
See here:
Maytag Dryer Belt Routing
belt routing for maytag performa ... -
Maytag gas dryer belt routing - FixYa
Sep 18, 2008 | Maytag Dryers
Maytag PYE2300AY Electric Dryer Logo
1,170 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
