Question about Kenwood DNX7100 Car Video Player
Disconnected cable Ok so i tried to install my dnx7100 and it tells me disconnected cable..i try taking it to 3 different shops but they don't seem to know whats the prom can some one tell me
    Problem Solver:
  • 5 Answers
Does it happen to give you any other additional information? Like what screen is it on that displaye disconnected cable? Have you tried the restart button?
Posted on Aug 08, 2008
I accidentaly disconnected my Samsung 60" tv picture when I tried to move the tv to watch it from a different angle in the room. Everything else is still working but no picture?
You might want to check what got disconnected. If it was an HDMI cable to your cable box, Either the cable or input port on the TV could have been damaged. Try a new cable and possibly a different HDMI input port. Also try watching a DVD through the same port to see if the input is OK. If the above doesn't work, check that you can at least bring up the setup menu on the TV. No menu could indicate a damage display panel or driver...
Feb 02, 2015 | Samsung Televison & Video
Tip
Tips for Media state Media disconnected or Network cable Unplugged
Wired adapter or NIC Local Area connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a physical device or connections
Solutions: 1. Try with a different port on the switch or the router. It could be the fault with the Router/Switch port 2. Try a different Ethernet cable. It could be the fault with the Ethernet cable 3. Try with a different NIC or a different computer. It could be the fault with the NIC
Wireless adapter or NIC
Wireless network connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a some device issue or the wireless settings
Solutions:
1. Try scanning for wireless network and reconnect 2. Remove the profile or preferred networks from its list 3. Check and make sure the SSID and the Security KEY are correct 4. Restart the computer 5. Try with different security types like WEP,WPA or WPA26. Check if the MAC filter on Router/Access point is enabled
on Aug 21, 2010 | Computers & Internet
1994 Buick LaSabre won't shift out of park--brake lights OK, transmission OK after I disconnected shift cable on transmission--eingine/car runs fine--any ideas?
brake lights will be ok as there is a different wire from the switch for the interlock system just jumper the wires at the switch you should see 2 different wire connectors
Sep 18, 2014 | 1994 Buick LeSabre
When i installed my radio its reading usb error
hit done? But first read through the manual and see if there is any sort of initiall startup procedure. (unlikely)
Then try checking all connections. If that doesn't work, unplug, check for the right connection ports, and replug everything. If it still doesn't work, take it to a professional or return it and buy a new one, it could just be defective.
May 01, 2012 | Kenwood DNX7100 Car Video Player
My criuse control dash button lights up but the cruise control doesnt work
With the light coming on as if it's working it is likly to be working it's just come disconnected some way. Most of the time the cable from the cruise unit to the throttle body comes off or the cable is broken ( less likly). There's likly three cables connected to the throttle body, ( the thing thats mounted to the engine that the air inlet hose connects to that is coming from the air cleaner box) One will be the gas pedal and right next to it is the cruse and on a different angle theirs a cable that connects to the transmission. With thte car shut off you can watch the cables and touch them as someone steps on the gas pedal and makes them move the one that tightens up is the pedal and so the other that pulls the same way is the cruse. If you've never seen it work it might be because major work has been done some time or other and the mechanics did'nt hook the cable back up, or a previous owner did'nt want it to work and had it disconnected. If you find it unhooked and you don't know why. be careful as you first try to use it as it might be disconnected because it does something wrong. ( go faster and faster, or won't shut off). Most will stop if you turn off the key but until your shure it works OK do'nt use it any where that turning the car off and pulling to the side of the road is easy. ( in other words be ready for it to do something wrong). Once you figure out why it's been disconnected, tell me what it did and i'll trey to tell yu how to fix it. I need the engine size and the country the car was bought new In to help you alot.
Jun 21, 2011 | 2000 GMC Sierra
Hi my name is Ana this morning the RTL818X seems to be disconnected, it works ok everyday but today a red cross is on it how can I change it?
It seems that the network (ether net )cable is disconnected.
Please check whether network cable or Wireless network is disconnected.
Mostly, the Ethernet cable would have been disconnected in other end of it.
Please plug it properly. It should resolve it.
Jan 27, 2011 | Computers & Internet
Uday.sourav@gmail.comMy HP DeskjetF380 all in 1 printer is not working at all. I tried millions of times but it does not start. There was no problem with the data cord. I think it is a internal problem....
check if you are having power, then if power is present after switching on does it initialize i.e ready to receive data. if yes try a self test page with the printer still disconnected from the pc. if it comes out ok connect your data cable and attempt to print a test page. if it comes out ok try a print job. if not try to change the data cable if still not working try re installing drivers. if you still dont come right try it on another pc. if nothing positive happens take it to a repair shop.
Sep 27, 2010 | HP DeskJet F380 All-In-One Printer
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
Kenwood DNX7100
or the parking prake wire is not grounded... that's what happened to me. Just find a spot to ground the parking brake wire and video should appear.
Feb 15, 2008 | Kenwood DNX7100 Car Video Player
Kenwood DNX7100 Car Video Player Logo
227 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
