Question about Whirlpool Washing Machines
My washer does not drain after the rinse cycle
After I start a load of laundry my washer will run and the agitator will even work but the washer just stops after that NO SPIN CYCLE,NO DRAINING,
  • 413 Answers
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, replace lid switch.
Posted on Jun 01, 2008
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
My washer wont rinse. It seems to have a hard time spinning, any suggestions?
do you hear the motor running ,it will drain but no spin,this has no belt in it it's built just like a whirlpool washer because whirlpool owns maytag now and this washer has a motor coupling,i would check this first,do you know if the agitator is working or do you hear a grinding noise when it's running?watch this video and you don't have to disconnect the wire harness to the motor if you don't want to,i don't just put motor off to right side still connected
http://www.youtube.com/watch?v=9K1KHEogf3c
Apr 09, 2013 | Maytag Centennial MTW5800TW Top Load...
Wife did a load of laundry. he washer filled and started to work but it would not drain spin or rinse. it will keep running the agitator if I turn the nob its self.
check for a bad door safety switch, you can locate the switch and the connection plug and unplug the switch, and add a jumper wire between the 2 connectors that lead away from the switch , spin, rinse, and drain, need this switch to work or the machine doesn't do those motions,
Jul 27, 2011 | Kenmore Washing Machines
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool top loader washer not agitating
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
I hope this helps you.
Vic
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Washing Machines Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
