Question about NEC IT3510 Copier
NEC IT 3640 copier - login screen with user name and password appeared. We have no user name or password programmed into the copier. How can I get pass this screen?
How can I get into service mode for NEC IT 3640.
Ok, I realize this machine is already EOL, but if anyone else runs into this issue, I found the answer here.
  1. Press the "Utility" button
  2. Press the "Access" button
  3. Press * four times
  4. Press the "Maint" soft button on the touch screen
  5. Press the "Service Mode" soft button on the touch screen
Once you are in there, you can reset the admin password by pressing the "Administrator # Initialize" soft button, and that will reset the admin password back to the default 00000000. Evidently, this works for a few other models of NEC copiers as well.
May 08, 2014 | NEC Office Equipment & Supplies
Entering service mode on an nec 2840
Once you are in there, you can reset the admin password by pressing the "Administrator # Initialize" soft button, and that will reset the admin password back to the default 00000000. This is actually for an IT3640, but evidently, this works for a few other models of NEC copiers as well.
Dec 11, 2013 | NEC It 3640 2530 3530 2840d Copier...
How can I get my login password for windows
I take it you are running Windows Vista Home Basic? Do you have more than the one account on it that can download programs?If the answer to both is yes, then try this:
1.Download and install ophcrack with recommended settings.
2. Run the ophcrack program and it will scan your laptop for all Windows user accounts.
3. The Windows user names will appear in the top region of the screen once the search is complete.
4. Click on the user name you desire to recover a password for. Your password will be extracted and displayed in the "NT Pwd" column on the right side of the screen next to your user name.
5. WRITE THE PASSWORD DOWN.
6. Restart the computer through the Start menu.
7. Login to the account you just recovered the password for.
Sep 13, 2013 | Toshiba Satellite A205-S5803 Notebook
I forgot my login password to my toshiba loptop how can i reset my old password because icnt remember my current password
1.Switch ON/Boot the system,
2.Login screen appears Press Ctrl+Alt+Del
3.User name:Administrator Press ok
4.Right click on My Computer icon in desktop-select Manage-Select Local users &Groups(LeftPane)-double click on Users (Right Pane) -select your username -Right click-Reset password-here you can set the password-ok
5.LogOff &Login again
Jun 17, 2011 | Computers & Internet
Another business we share an office with wants to use our photocopier. How do we set up their own password to enable this to work.
You can always find solutions to Xerox problems @ www.xerox.com/support Once you set this up both you and your neighboring business will BOTH have to use individual codes. Hope it helps!
Solutions for : How To Set up or Modify Auditron User Accounts Solution : Set up or Modify Auditron User Accounts The following information describes how to register userIDs and usernames, login names, and passwords for authenticating accesses attempted through the network for scanning services, and impose restrictions on the maximum number of pages to be copied or scanned. Up to 500 user accounts can be registered.
NOTE: You must be a System Administrator to perform this solution.
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [Login / Auditron Administration]. The Login Setup / Auditron Administration screen will be displayed.
  7. Select [Create / Check User Accounts]. The Create / Check User Accounts screen will be displayed.
  8. Select a user account number or use the numeric keypad to enter a user account number in the Go to (001-500) field.
  9. Select [Create / Delete]. The User Account screen will be displayed.
  10. Enter a userID using the keypad on the Touch Screen, and then select [Save]. The Create / Delete screen will be displayed.
  11. Select from the following options:
    • UserID: Allows a userID to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • User Name: Allows a username to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • Password: Allows a password to be entered using the keyboard on the Touch Screen. 4 to 12 alphanumeric characters can be entered. The Password button is also displayed if a password was selected on the Login Setup / Auditron Mode screen.
    • Remote Login Settings: The following settings can be modified on this screen:
      • Login Name - Allows a login name to be programmed that needs to be entered when the machine is accessed through the network.
      • Password - Allows a password to be programmed that needs to be entered when the machine is accessed through the network.
    • Account Limit: Select [Copy Service] or [Scan Service], and then select [Account Limit]. Using the numeric keypad on the Control Panel, specify and restrict the maximum number of pages to be copied or scanned for the account. The maximum number can be entered within the range of 1-9,999,999 pages.
    • Reset Total Impressions: Deletes all data tracked for the selected account.
    • Reset Account: Clears all settings and data for the selected account.
  12. Select [Save].
  13. Select [Close] three times.
  14. Select [Exit].
Feb 03, 2011 | Xerox CopyCentre C123 Copier Copier
Don't understand how to set password. please help
Plug the router into the power socket and configure you own machine to obtain IP address automatically. Load up Internet explorer and type in http:/192168.xxx.xxx which is the local address of your router. You should then get a password screen. Enter default user name and password and it will take you to the configuration screen. The full IP address and user name and password are dependant on which model you have. See list below From there you need to read the instructions very carefully and match it with the information provided by your ISP.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
? Q: What is the default IP address, username, and password for routers? ? A
ZSR0104
192.168.8.1
Administrator password: admin
ZSR0104M
192.168.1.1
Login password: No Password
ZSR0104B
192.168.1.1
User Name: admin
Password: 0000
ZSR0104AS-01
192.168.8.1
Administrator password: No password
ZSR0104E
192.168.2.1
ZSR0104CP (Grey color)
192.168.1.1
User Name: admin
Password: admin
ZSR0104CP-05 (Blue color)
192.168.10.1
User Name: guest
Password: guest
ZSR0104WE-01
192.168.2.1
ZSR0104WE-04
192.168.2.1
User Name: admin
Password: 1234
ZSR0104WE-05
192.168.1.254
User Name: admin
Password: 1234
ZSR1104WE
192.168.2.1
User Name: Empty
Password: Empty
ZSR0104DE
192.168.2.1
ZSR0104FS
192.168.1.1
User Name: admin
Password: admin
ZSR0104UP
192.168.1.1
User Name: admin
Password: 0000
Dec 22, 2010 | Zonet Computers & Internet
How to make an hp laptop go to the log in screen
The login screen will not appear if you have Windows set to login automatically. You will have to log out first. Try this:
Save & close all programs you have open.
Click the START button
Click LOG OFF
When it asks if you want to log off, click LOG OFF
The login screen should now appear
If you want to change your password, picture, or add or delete accounts, you need to login again, then follow these steps:
Type in password and login
Click START button
Click CONTROL PANEL
Go to USER ACCOUNTS
From here you can make changes to login and user account information
Oct 24, 2010 | Computers & Internet
Need to establish PIN/Code for machine - help xerox c123
  12. Select [Save].
  14. Select [Exit].
Jan 08, 2009 | Xerox CopyCentre C123 Copier
I am trying to install a photosmart all in one C5180 on my pc running Vista. It keeps saying that the program cannot be installed as use by and asking me to log on as the Administrator. I AM the...
This is normal with Vista, Vista log in users as standard (not Administrator privileges) , then ask if to run programs as administrator for security reasons. Once you tell the system to run program as administrator it should install with no problems.
If you really cannot install the program, you can restart computer and login as administrator:
At the "pick a user to login" screen, hit CTRL-ALT-DEL to get the classic login screen. Then you can type in Administrator for the user name, default password is blank.
Read here for more.
Jun 08, 2008 | HP Office Equipment & Supplies
NEC IT3510 Copier Logo
363 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
