Question about Vacuums
Machine a coudre kenmore 15318 numero de serie 23004763
Pro heat 2X revolution
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines
Here is the Instruction or User Manual for the 9500 series machines..
Aug 16, 2017 | Vacuums
Pro heat 2X instructions
How can I get a user manual on line for bissell carpet cleaner as I have misplaced mine ans as yet have never used the machine
HOPE THIS HELPS YOU.
Oct 08, 2014 | Vacuums
I NEED TO CLEAN FILTER
Dec 30, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
I have a kenmore vacuum, Series 116-23613300. four years old. It is emitting a high pitch squeel. I have checked and the hose is not clogged, I have put in a new bag and I have washed the foam filter. ...
If the squeal is coming from the canister portion of the machine, then you most likely have a fairly serious motor/fan problem. There are no moving parts on that machine other than the fan/motor assembly in the canister.
A local service center could confirm that. You can try to get a free quote if they offer such a service. Many may charge a fee even for diagnostic work.
If the noise is coming from the power-head, then there are multiple possibilities ranging from bad brushroller bearings to failing power-head motor.
Apr 04, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Kenmore 1581784 manuel
Go to: Searspartsdirect.com and list the Sears model number minus the decimal point. You will get a series of drawings for various sections of the machine--hunt through them for the manual that you seek. Good luck!
Sep 19, 2010 | Vacuums
Should the arrow point in towards vacuum or out on the replacement exhaust hepa filter for my kenmore prgressive 400 series vacuum?
I'm assuming the arrow you are referring to is on a new dust bag. If that's the case, the arrow should be pointing down toward the bottom of the machine.
Jim Hart
Jun 20, 2010 | Kenmore 34613 Bagged Upright Vacuum
My steam cleaner will not get hot enough any more. It is only a year old.
probable scale problem in boiler. Try using coffee machine de-scaler add to steamer heat and rinse. De-scaler available from most stores selling automatic coffee machines. Or it may be an element failure.
Sep 13, 2009 | Euro-Pro S3325 Handheld Steam Vacuum
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
