Please whats the default ip for wipAir 3000 wireless radio? i cant get their usermanual from wave air site
2 Suggested Answers
pandeyram1
  • 192 Answers
SOURCE: What is the default IP address of WipAir 6000
see the user manual for best results.
Posted on Apr 05, 2010
I need to reconfigure my D-LINK wireless router. It is used and I do not have the administration or password.
This is from the 615 manual:
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
I've uploaded its manual to the Fixya site. That said both eecom and sargeon give correct answers; however, eecom's answer is very complete. It not only answers the initial question, it answers questions on how to securely setup the wireless router
Oct 18, 2014 | D-Link DIR-615 Wireless Router
Tell me how i resolve dns failed connection
ou can try these options. Please follow step by step instructions on your phone.
A. Reset Wi-Fi:
  1. Delete all the configured wireless connections.Settings-> Connectivity -> Wi-Fi -> Select Network
  2. Click on Forget
  3. Do this for all your connections
  4. Now Enable Wi-Fi again. And connect to router.
B. Using Static IP Address:
  1. Settings-> Connectivity -> Wi-Fi -> Select Network
  2. Make sure to disconnect the network if connected.
  3. Now open the network,
  4. Select Static IP
  5. Now you can assign IP Address
  6. Here are default ips (It may vary according to your router)
    IP : 192.168.0.2 or 192.168.1.2
    Subnet Mask : 255.255.255.0
    Default Gateway : 192.168.0.1 or 192.168.1.1
    DNS: any two of these =>
    • 4.2.2.5
    • 4.2.2.1
    • 208.67.222.222
    • 208.67.220.220
    • 8.8.8.8
    • 8.8.4.4
For screenshots visit http://www.samsungbadaapps.com/tips/dns-failed-error-on-wi-fi
Aug 12, 2014 | Samsung Wave 525 Cell Phone
I need to locate the default IP to my Linksys WAP200. The default has been changed and the owner cant remember what it was changed to. The owner cant afford to lose the configuration settings.
Plug a laptop into just the linksys. Make sure nothing else is connected. Then on the laptop go to start -> run and type cmd. In the black box type ipconfig. This should show you the ip settings on the laptop. There should be one with a default gateway filled in. This will be the lynksys's IP address.
May 31, 2011 | Linksys WAP200 (LS-WAP200) 802.11b/g...
HI SENAO 2611CB3 DELUXE REPAIR IP DONT HOW TO RECOVERY IP IP 192.1681.1. DEFAULT NO ANSWER NO CONNECTION THANKS LOST DEFAULT IP SAMMY
192.168.1.1
if you cant open it then reset router by pressing with toothpick the tiny button for 5 seconds while its on power.
if i was helpful please vote ..
Nov 01, 2010 | D-Link Computers & Internet
Have billion bipac 5200n installed on pc aiso servicing 2 wireless laptops . intalled a wireless - g usb adapter (netgear )on 2nd pc now laptops cant access net , saying invalid password any help...
dear sir good day please do reset the device from the sided reset button and the put in the settings for it and make Mac address filter from the wireless management tab and put a pass work on the sec tab so no one can get into your device and use it or bypass the settings ... thank you
Dec 26, 2009 | Computers & Internet
I'm trying to configure add my dell dimension 3000 to a netgear wireless router via a linksys devise. This would be adding a 2nd computer to the wireless router. I know the password. I'm getting a error...
Do You have an association button on Your router? If so, the firstly press the button and then try to connect. If not, You must enter IP address of Your computer, like 192.168.0.5 Subnet mask, like 255.255.255.0 IP address of router, like 192.168.0.1 Then, most important - default gateway. If You have another computer connected at the same router, run cmd, then ipconfig in the black MS DOS window that appears after cdm command. Here You can see all parameters of Your TCP/IP configuration. Take a note of the default gateway and put it to TCP/IP settings of Your Linksys device. If it not help, drop me a message.
Sep 10, 2009 | Dell Dimension 3000 PC Desktop
Cant get the wireless connection through the AP router
first check ur computer IP address (if not getting from DHCP then try static IP address) & default gateway.
Mar 20, 2009 | CTG 54Mbps WIRELESS ACCESS...
How do I setup filters on my wireless router?
IP Filters IP filters block access to ports or a series of ports from an IP address on the LAN. For example, if you did not want the computer with IP address 192.168.0.100 to access the Internet, then you would block that IP address from accessing port 80. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select IP Filters using the radio buttons. Step 5 Select the Enabled radio button. Step 6 In the first field next to IP enter the IP address you want to block access from. If you want this to apply to a range of IP addresses, then enter the ending IP address in the second field. Step 7 In the first field next to Port enter the port you want to block. To block a range of ports, enter the ending port number in the second field. Then select the protocol type (TCP, UDP, or Both) using the drop-down list next to Protocol Type. Step 8 Next to schedule select Always using the radio buttons to continuously enable this filter, or select the From radio button to set a schedule using the time and day drop-down boxes below. Step 9 Click Apply and then click Continue to save the new settings. URL Blocking URL Blocking is used to block web sites that contain certain keywords. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select URL Blocking using the radio buttons. Step 5 Select Enabled using the radio buttons. Step 6 In the text box below enter a keyword to block. To delete a keyword, select it from the box below the text box, and click Delete. Step 7 Click Apply to add the keyword to the list. MAC Filters MAC Filters allow you to allow or deny access to the LAN by specifying MAC addresses. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the (default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select MAC Filters using the radio buttons. Step 5 In the section MAC Filters, select the radio button for the mode you would like to use. Disabled - Disables this feature and will allow all wireless clients to connect. Allow - Blocks all clients except for what you enter in the list. Deny - Allows all clients except for what you enter in the list. Step 6 Enter the name used to identify the entry next to Name. Step 7 Enter the Ethernet MAC address that you wish to Allow or Deny next to MAC Address. Step 8 Click Apply and then click Continue to save the new settings. Domain Blocking Domain blocking lets you allow or deny access to certain websites. Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click OK. Step 3 Click the Advanced tab and then click Filters to the left. Step 4 Select Domain Blocking using the radio buttons. Step 5 In the section Domain Blocking, select the radio button for the mode that you would like to use. Disabled - Disable this feature and will allow all clients on the LAN to access any website. Allow - Permits access to all websites except domains specified in the Blocked Domains section. Deny - Allows access only to domain specified in the Permitted Domains section. Step 6 In the Permitted Domains section, enter a domain to permit. In the Blocked Domains section, enter a domain to block. - or To delete a keyword, select it and click the Delete button. Step 7 Click Apply to add the domain the list.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
