Question about Packard Bell Computers & Internet
Hello there, I can't reinstall Windows XP. When loading the reboot DVD, my both computers mention they can't find the device. Which device they can't find is not clear. Both computers are set up to reboot from the DVD drive. My both computers have 1 thing in commun: Ubuntu has been installed on it. So this is my major question: what can I do so the computers can read the windows xp reboot DVD. Thanks in advance.
  • Benedict Baron Oct 11, 2010
    do you want to run linux and windows together if so do you have two boot partitions that you change in your bios
  • 2,229 Answers
Even though you have set the computer to boot from the DVD first, there is usually a special function key you can press to ensure you boot from it.
Just when you get the error will determine what the problem may be. When you first start, you should get the prompt "press any key to boot from the CD (DVD). If you don't get that prompt, then your DVD may be going bad on you.
You say you are loading a reboot DVD. I have no idea what that is, but XP was distributed on a CD for the most part. Be sure you are trying to boot from the original Windows XP CD or a system restore CD.
If you are allowing the computer to boot to Linux first, then you're in for trouble. That won't work.
Posted on Oct 11, 2010
Hello! I had to reinstall windows xp, on my computer. Now when I tried to load my games back on, Some of the disk are not working. The green light comes on and I can hear it spinning, but the Icon never...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 19, 2011 | LG GDR-8162B Internal DVD Drive
(Vista) Toshiba - Matshita DVD-ram problem.
DVDs do not need any driver, the DVD is faulty and must be fixed or replaced.
Nov 27, 2008 | Toshiba Style Bay DVD-RAM Drive Kit...
My netbook n150 plus is displaying "no operating system detected" HELP!
Hello!!
1. To repair it put your Windows 7 DVD to dvd tray (any windows 7 DVD will work oem/retail)
2. boot from it
3. when you reached to the Installation Screen, At bottom You'll find Repair Windows Option.
4. Hit that option and let it do start up repair automatically and let it reboot..
5. on reboot after repair please remove your DVD to let the Netbook boot from HDD rather than DVD.
If the above mentioned solution fails then, you should reinstall the OS.
Jun 05, 2011 | Samsung N150 (36725723009) Netbook
I cant reinstall xp, it keeps asking for a restore cd, how do I go around this?
This may be of interest to you. I might not be seeing this exactly, so please bare with me.
Possibly, you are not doing the following
Tell your bios to make your dvd for now your 1st drive.
Insert your windows XP setup disk in your dvd drive and reboot your computer.
Your windows XP cd will ask you to push any button when your computer sees your dvd drive while booting up and will begin loading the drivers for your computer.
I think this was lacking. Enjoy
Mar 27, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
I have a Toshiba A-305 w/ Matshita DVD-RAM UJ880ES. In the device manager under Device Status, it states "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing....
This is a common issue and error with Mashita drives. Especially the error 39. I have ran into this problem with several clients. It's a simple fix. Go to the following link at Microsoft's website and follow the instructions for editing your registry. Be careful and follow the instructions exactly, Make sure you back up your registry before deleting the two keys they mention in the article. I have successfully fixed this problem on several occasions. Good luck.
KingPin Computers
http://support.microsoft.com/kb/314060
Jan 06, 2010 | Computers & Internet
Xp pro will not load
HELLO THERE:
when you start the computer hit the f-8 key repetedly and the xp pro advanced boot screen should show up now select last known good configuration that worked then hit enter and the computer will reboot and hopefully this will get you going also make sure there is no cd rom in the drive ok? please let me know how this goes there is more we can do if needed please dont forget to rate the solution i have provided this helps me out as well
best regards mike
Aug 06, 2009 | HP Pavilion N5350 Notebook
Reboot
To Reboot a computer is to turn it off, wait at least 20 seconds, then turn it back on.
A.If you're thinking of Reboot, as to reinstall the Operating System, you use a Restoration Disk, (sometimes listed as Recovery Disk), insert it in your CD/DVD drive, and restart your computer.
(Just press the CTRL, ALT and Delete keys AT THE SAME TIME.
Not shouting. Windows XP and Windows Vista are examples of an Operating System)
B.If you're trying to install an Operating System, from a CD disk that you bought, I suggest you go into BIOS Setup, and in Boot Order, change the first boot device to CDROM. Insert the CD disk in your CD/DVD drive, and restart the computer.
If you buy a Full Installation CD disk, as listed above, you have to change the Boot Order.
For example:
1.You have Windows XP on your computer now. It has problems, and doesn't work correctly. Instead of getting the Restoration Disk from your computer manufacturer, you decided to just buy a genuine copy of Windows XP, and install it. (This is a Full Installation Disk)
The Windows XP you have installed now, will not let the one you bought install over it, by just putting the disk in the drive. Change the first boot device, in Boot Order to CDROM, and it will. The Windows XP you have now, will 'see' the Windows XP you're trying to install, as just the same version. You have to install a better version of Windows, in order for it to write over what is installed.
Such as Windows Vista.
2.You have Windows Vista on your computer, and are not happy with it. You would like to put Windows XP on instead. Windows XP is considered a lesser version, and Vista won't let it write over it.
Go to BIOS Setup, change the first boot device in Boot Order, to CDROM, and it will.
May 10, 2009 | Compaq Presario R3000 Notebook
Not displayed in my computer, but displayed in device manager with yellow exclamtion mark code39 driver error
Install its driver I think. If this device is in the yellow mark in device manager. Have it go to update driver or install driver. The exclamation mark should be gone. Or better install its bundled software application
HOPe this one helps
Apr 25, 2009 | NEC ND-6750A DVD RW Dual Layer Burner
Can't install OEM Windows XP on fresh hard disk
please check the consistancy of hard drive or try to run a zero format first and then reinstall the win
Apr 15, 2009 | Computers & Internet
Internal laptop CD/DVD combo drive problem
1. uninstall dvd/cd using device manager reboot and winxp will reinstall driver 2. go to my computer / dvd drive / right click / properties / hardware - roll back or update & properties - enable digital cd audio / recording - enable cd recording 3. do system restore start / all programs / accessories / system tools / system restore 4. do full system recovery - us windows xp OS
Nov 23, 2006 | Acer (91.AB264.016) Internal 24x CD-ROM...
Computers & Internet Logo
79 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
