Question about Kenwood KD-291RC Turntable
Hi, I'm trying to refit the belt but could not work it out from the other posting/answer HELP please
Me 2
Posted on Jan 24, 2011
My Peugeot Partner has a 1.9 diesel engine. The serpentine belt recently burst so I purchased a replacement but I would like some guide on exactly how the belt should be placed around the pulleys.
If this belt broke then remove the timing covers and check for bit of belt inside around the timing belt before you go any further .its quite easy to refit a new fan belt but they can vary with the year as earlier ones had a manual adjuster but later models are spring loaded so check the timning belt belt first then if ok answer this post and i will scan my alldata book for you as its late and iam going to bed before i fall asleep over the keyboardss
Jan 30, 2013 | Peugeot Cars & Trucks
Kia sedona instructions to replace serpintene belt
Hi, Here is the procedure for a 2002 KIA Sedona 2.9, Engine code KJ. I I can not guarantee the followingprocedure is exactly the same as your car.
Warnings and recommendations Unless otherwise advised by the manufacturer, the following procedures are recommended: Always fit a new timing belt after removal Check the tensioner and idler pulleys; renew if necessary Never turn the engine in the direction opposite to that of normal operation Check the belt(s) for cracks, fraying, wear and oil contamination Note: The engine must be cold before timing belt adjustment Note: Avoid bending, torsion or traction General Before disconnecting the battery cable, check the audio system security code kj_t_dba_uk_6.jpg
Always check the timing marks before timing belt removal Removal Disconnect the battery Remove the radiator upper hose Remove the fuel filter unit Note: Do not disconnect the hoses carniv_j3tci_t_dba_uk_3.gif
Remove the bracket Remove the right front wheel Remove the air-conditioning drive belt Remove the ancillary drive belt Remove the ancillary drive belt tensioner Remove the coolant pump pulley Remove the crankshaft pulley Remove the timing cover(s) kj_t_dba_uk_6.jpg
Remove the tensioner Remove the timing belt Check the gearwheels, tensioner and idler pulley(s) for damage and wear Renew if necessary Installation kj_t_dba_uk_6.jpg
Align the marks on the tensioner Tighten the tensioner (23.5 Nm) Rotate the engine 2 rotations by hand kj_t_dba_uk_6.jpg
Check the tensioner Repeat the procedure if required Refit the timing covers Refit the crankshaft pulley (373 - 392 Nm) Refit the coolant pump pulley (17.6 - 28.4 Nm) Fit the ancillary drive belt tensioner Fit the ancillary drive belt Refit the air-conditioning drive belt Refit the front right wheel (88 - 108) kj_t_dba_uk_4.gif
Fit the bracket (36.2 - 53.9 Nm) Refit the engine mount carniv_j3tci_t_dba_uk_3.gif
Refit the fuel filter unit Refit the radiator hose(s) Refill the cooling system Check for leaks Reconnect the battery earth cable Torque settings Tensioner: (23.5 Nm) Timing covers (6.9 - 9.8 Nm) Coolant pump pulley: (17.6 - 28.4 Nm) Special tools Special tools are not required
Jan 06, 2013 | 2004 Kia Sedona
Zwf12070w1 replaced belt now very noisy on fast spin
Hi. Your mistake with not tentioning the belt when you switched probably caused your main bearing to shot. Check if your motor is centred with the drum
Apr 27, 2017 | Zanussi Washing Machines
Getting bolts in after changing alternator w/the belt tight
You dont its that simple ,remove or slacken the belt then fit the bolts and refit the belt ,would help if you posted the make and engine type of the vehicle
Dec 02, 2011 | Cars & Trucks
Instructions for installing BT3000 saw belts
Please see operating manual available for download here. That includes an exploded parts diagram, which may help you get the new belts on. Otherwise, you might try contacting an authorized Ryobi service center and asking for assistance. I'm afraid I've never worked on one of those saws.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 10, 2011 | Saws
Belt has come off from drive pully to drum wheel. when trying to refit, belt runs off drive pully when i turn drum wheel by hand. machine not that old and belt in good condition (checked it against new...
I always recommend the purchase of a new belt anyway- but you appear to have one!
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 07, 2011 | Washing Machines
Hi i am trying to fix my belt on a beko condenser dryer as the old one has snapped can you help me please.
remove all the screws from the back panel and remove the heater cover (shaped inner panel fastened to the back panel).remove the cir-clip from the drum shaft and you will be able to pull the back panel away far enough to drop the belt down between the drum and back panel.refit in reverse.take the cover plate off the back/bottom right corner and using a tube or screwdriver,stretch the belt over the motor pulley.refit cover plate.job done
belt diagrams:
http://www.applianceaid.com/images/belt-config.JPG
Jan 08, 2011 | Dryers
MY GE Washer WCRE6270G0WW wont spin or agitate. Please help
IT SOUNDS LIKE YOUR DRIVE BELT HAS BROKEN FIRST TURN OFF POWER TO MACHINE THEN LOCATE THE SCREWS AT THE BACK PANEL AND REMOVE THEN OPEN PANEL AND LOCATE DRIVE BELT REMOVE AND TAKE IT TO A ELECTRICAL AND PLUMMERS SUPPLY STORE FOR REPLACEMENT THEN REFIT BELT TO MACHINE AND IT SHOULD WORK FINE ,.
Nov 30, 2009 | Cars & Trucks
Would like to know how the calling cards works
Your question is best answered by the following site.
There are answers to many question about calling cards here.
http://www.ask.com/bar?q=how+does+a+calling+card+work&page=1&qsrc=178&ab=0&u=http%3A%2F%2Fwww.distanto.com%2Finternational-calling-cards.html
If I have managed to answer your questions and have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot give this post a “FIXYA” rating then please comment to this post and I will try to help you further.
May 20, 2009 | Computers & Internet
Kenwood KD-291RC Turntable Logo
47 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
