Question about Lithonia Lighting Psq500 Power Sentry Inverter Charger
I had a Psq500 Power Sentry ballast that caught on fire. This is the follow up response from the local electrcian "This was a very old ballast. It was actually the emergency lighting ballast (the one that runs on a battery so that incase the lights go out, one bulb will remain running on the battery power of the emergency lighting ballast), so he figured that the battery somehow short circuited in the fixture, causing it to start smoking and eventually cause a few flames. This was a very rare, one time occurrence." Asked if all other ballasts should be inspected or if this was an indication that the others will be going out soon and potentially causing the same issues in other fixtures and he told me "no on both accounts." Have you experienced this before?
2 Suggested Answers
  • 760 Answers
SOURCE: no power to lighting ballast
Follow the appropriate wiring exactly. There are about 6-8 different diagrams. Find your lamp type and number of lamps. Locate your ballast type (usually instant these days) Quite often these diagrams show a switch on the power lead going to the operating ballast. If it isn't on a switch be sure to wire it in with the lead to the emergency battery ballast.
Posted on Jul 01, 2010
Open sentry safe key
contact sentry safes customer support or your local locksmith
if in Fort Lauderdale area try
Mar 23, 2014 | Sentry Safe SentrySafe Safe. Fire Safe 1.2...
How to open sentry safe sfw123cs
Anon, Contact a local locksmith, most of them are skilled in opening small safes when code or key lost.
Check the attached links,instruction and guides on how to open your safe. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
SFW123CS Combination Fire Safe
http://content.etilize.com/User-Manual/1027349209.pdf
How to open sentry safe sfw123cs Sentry FIRE SAFE Combination Safe DS3431...
Emergency Locksmith Services Aim Lock Safe
Jan 21, 2012 | Sentry FIRE-SAFE Combination Safe DS3431,...
Loud sound when it is on
Cooling fans can sometimes be a source of noise, as can loose windings on the transformer. If it is not overheating and funtions normally, the noise is just something to live with. It is not always considered a defect, but you can ask the vendor about it.
Jan 13, 2012 | Lithonia Lighting Psq500 Power Sentry...
Lost the combo to my sentry 1610 safe, need the company master combo
Hi.
If you have lost the combination you need to follow detailed procedure needed to retrieve the key from Sentry. For security reasons there is no other way to get a master combo.
Please follow the instructions detailed in this link.
Regards.
Ginko.
Nov 16, 2010 | Sentry Safe Fire-Safe Personal Safe
JVC DLP MOD#HD55G466 what is the voltage from power supply to ballast and into the lamp.I have no voltage to the lamp could it be ballast?
Ballast board gets voltage from power supply connector CN90BL and volts readings are as follows:
Pin-1 = 380V DC
Pin-2 = Ground
Pin-3 = 15V DC
and output of ballast board would be 12,000 volts AC that goes to lamp to generate spark in its electrodes to produce high bright light.
If you get volts on input of ballast board but still lamp does not fire up then ballast board is not working.
Ballast board part number is QAL0765-001 and available with tv-part.com for $125
Hope these info will help you.
Thanks.
Nov 16, 2010 | Televison & Video
I need a lithona lighting power sentry psdl3 wiring diagram
http://www.lithonia.com/SpecSheets.aspx
Lithona has a lot of products and they show the manuals.
Unlike a lot of companies where manuals are not available, as if customers live in the 1980's and still write to companies asking for information.
I don't see your speicific product at Lithona.
A search for 'power sentry' turned up many possible products.
Unlike a lot of sites that just say, 0 results.
Many times, the same product will have more than 1 name or product-number depending on who is selling the product >>> that's how different companies can sell the same product but claim their product line is unique.
You might search the manuals at Lithona and find a similar product under a different name or number.
Oct 15, 2010 | Lithonia Lighting Psq500 Power Sentry...
The florescent ceiling light in my kitchen takes a long time to turn on after flipping the switch. It is a lithonia light model# 764123
Flourescent Lights use a 'starter' to build up a charge which then jolts them to life. It sounds like your starter is struggling to do the job. The starter is usually located on the side of the light casing and looks like a cylinder which partly protrudes from the case. It twists and comes out and is easily replaced.
Jul 17, 2010 | Lithonia Lighting Psq500 Power Sentry...
No power to lighting ballast ,only lights up on loss of power 277v at emergency ballast
Jun 30, 2010 | Lithonia Lighting Psq500 Power Sentry...
Kill power to light and emergency single light does not turn on also with power on push test knob and emergency bulb not come on
Hello Ramon, Check the power back (battery cell) as without a functioning battery pack, the emerbency light won't function.
Typically the batery packs will need to be replaced periodically every 4-5 years, depending on the istallation location and ambient temperatures.
When you kill the power to the emergency lighting circuit the PSQ is switched to operate automatically on battery power only. The same thing occurs when you press the test button; it disconnects the lighting from the electric power that keeps the battery charged and ready for service. You might also want to check the bulbs with a test meter (remove the bulbs from the fixture and test with the Ohm setting) While rare that these bulbs burn out, since they aren't usually illuminated often, only during a power disruption/outage, etc.
Here's a link to the Lithonia site with the spec sheets for the PSQ series of emergency lighting products, for your use and reference.
http://www.lithonia.com/product/advSrch.aspx
I hope you find this Very Helpful and best regards!
Nov 24, 2009 | Lithonia Lighting Psq500 Power Sentry...
Changing ballast
Here is the link for wiring Lithonia Power Sentry Ballasts: http://www.acuitybrandslighting.com/Library/LL/documents/Installation%20Instruction%20Sheets/PS.pdf
Hope this helps Sparkylikes480
Mar 27, 2009 | Lithonia Lighting Psq500 Power Sentry...
Lithonia Lighting Psq500 Power Sentry Inverter Charger Logo
87 people viewed this question
Top Lithonia Lighting Electronics - Others Experts
Are you a Lithonia Lighting Electronics - Other Expert? Answer questions, earn points and help others
