Question about Amana Washing Machines
Amana front loader washer Model# NFW7200TW. Keeps shutting down and shows the digital reading of E3.
  • Amana Master
  • 19,396 Answers
It means there is a problem with electronics, Amana indications are to call the service
Posted on May 31, 2008
  • Ginko
    Ginko May 31, 2008
    E3 is displayed when
    there is a control or electronic error. Try disconnecting the power cable for one hour or so, if you still get the message, you will have to test the control board.
    New Friend:
Also unplug it for one minute. And then plug it back in and open and shut it 6 times in 12 seconds.
This will reset the washer.
Posted on Apr 14, 2015
  • tiffani rose Apr 14, 2015
Amana front load washer error E3
https://www.youtube.com/watch?v=fx7Lrj7gEy4
Jul 06, 2015 | Amana NFW7200TW 27-in. Washer Front...
The little door that opens to let water into machine(front loader) does not open. Why?
Links to sears parts direct. First link is to download manual, see page 11 Clean dispenser.
NFW7200TW10 AMANA RESIDENTIAL WASHER Manual
Second link is to parts diagram. images can be changed in size.
Second image from left is the dispenser.
AMANA Residential Washer Parts Model NFW7200TW10
Sears offers trouble shooting help also look for trouble shooting in user manual.
Sep 21, 2014 | Amana Front Load Washing Machine Washer...
MY MAYTAG NEPTUNE FRONT LOADER WASHER KEEPS SHUTTING OFF AND THE E3 ERROR MESSAGE IS ON THERE
Transmission or clutch assembly not engaging due to going out or slipping. even bad door switch
Sep 20, 2014 | Maytag Washing Machines
E3 trouble code
E3 Error: Machine control is attempting to drive the motor but is not seeing any tacho response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). The hall sensor is a circuit in the motor. the motor will need to be replaced. Here is a link to the motor.
Mar 22, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
I have a NFW7200TW Amana Washer. The problem is my wife said she saw a E3 error and then a nd error. I fixed the pump for the nd error but I don't know what the E3 error is. When I tried to run th
E3 Error: Machine control is attempting to drive the motor but is not seeing any tach response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). Replace the hall sensor.
The "hall" sensor is an internal circuit of the motor. It "tells" the machine control board, what the motor is doing, it's similar to a tachometer on the dashboard of a car. In your case, you want to do the resistance checks on the wires of the CN9 and CN8 connectors at the main control board in the front of the washer (it's easier and more indicative). Unplug the CN9 connector from the control board(red, white and blue wires) testing the pins inside the wire harness connector: from pin#1 /blue to pin#2 /white you should read 3 ohms resistance from pin#1 blue to pin#3/red, you should read 3 ohms resistance. from pin#2/white to pin#3/red, you should read 3 ohms resaistance. That will tell us the motor windings are damaged or not. At the CN8 connector, unplug the connector from the control board and insert the meter probes into the end of the wire harness connector; pin#4/orange to all other pins in the connector should have infinite resistance. pin#3/blue to pin#1/pink should have 4.7 ohms resistance. If you have these resistances, the motor and wiring are OK and you'll need the control board. If the resistances are not within 10% of the ones listed, you'll need to check the wiring harnesses and connections from the control board to the motor, and replace the motor if all checks OK.
Oct 17, 2012 | Amana Washing Machines
Amana washer model NFW7200TW drain filter
Go to www.repairclinic.com and enter NFW7200TW. You will be presented with a list of common repair parts and may be able to view a generic Amana video showing disassembly and parts identification.
May 17, 2012 | Washing Machines
Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
Washing Machines Logo
614 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
